Help Me Build My Daily Commuter?
Kinni420 said:
Meh...mid-motor go go. bafang bbs02 kit with everything including battery. $888 from Lunacycle. Ill never ride a hub motor again.
Just looked at Luna and priced it out, mine came closer to 1000...what battery did you go for and what's your top speed?
reluctantsuburban said:
motomech said:
Wtuber posted while I was typing.
The Q100 mini is a little smaller than the Ebiking mini, but, as you can see, the difference in size between a DD and a mini geared is profound!
Really briefly (replying from work), the ebay motor you linked says it is compatible with v-brakes, which I assume means I am good to go if I do purchase that Trek. Just FYI! Thanks for all the feedback.
Oh, I missed that. Yes, good to go.
MadRhino said:
Difficult to upgrade and tune the rear suspension of an old Trek fuel to build with a DD hub. The small air shock won’t do, and it has no room for a significant RC shock. Not a bad bike, but more suitable for a small geared hub or a BB drive. To build with a DD hub on a Trek FS frame, you’d better be looking at the Session series. In 2003 yr, the Trek frame I would choose is the diesel.
The weight of DD hubs, and the power that they are capable of, require a suspension design that has room for a big shock and a linkage with very good lateral stiffness. Not saying you can’t build a commuter on a Fuel, at the speed that you plan especially, but it won’t be upgradable. So if you ever plan to upgrade power and/or speed, you will need a better frame to make it a good ride.
The price is fair. That is what a 2003 Fuel is worth in average condition.
Hey MadRhino, thanks, this is helpful. I definitely don't know my MTBs. If I don't have plans to upgrade would you still say no the Fuel 80? Or if I went geared hub instead? Eager to hear your thoughts.
At this point in time, I can't see myself comfortably riding beyond 30 mph. Seems like a lot of people get into hot rodding, but I don't think my wife would approve :)
Am I looking at a different auction, or are you looking at this?
Package includes
Two Brake Levers with safety switches, V type and Mechanical Disc brake compatible, will not work on Hydraulic systems.
That doesn't really say anything about the rims. The closest I see to that is
You will be able to use your own brakes, cassette, freewheel.
The photos appear to show a machined rim brake surface - some of them do, anyway, while others show what appears to be a different rim that may or may not have a rim brake surface. I'd guess you'll get a rim brake surface, but I don't see them really saying that.
They are telling this because of the brake cut-off. They don’t supply the switch for hydro brakes in the kit.
I’d say go with the Fuel if you will not want to go faster. Order the rear motor in a 24’’ wheel, that will improve the bike’s geometry by slacking the steer angle, and the rider’s weight transfered on the rear will help the shock slowing the rebound of the motor wheel.
The frame has room enough to fit the battery and controller. That is making a build simpler.
You will build another one sooner or later anyway. So it is not so bad that your first is not really suitable to upgrade. This one will make you realize what you like and don't, and the next will start to shape in your mind.
I think I've told you, you will not be going 30 mph. 30 mph is superfast for an ebike. I was trying to get you to 25 mph. If you want to go 30 mph, double your budget, forget the Trek and buy the Frisbee sized DD motor and run 72 Volts. I'm not sure what the reason folks here are advocating an advanced build for a rank noobie. Now you are supposed to run two different sized wheels?? And what happens when the pedals hit the ground in the corners? You going to swap out the crank. I've been thru all that over the years, when you start changing one thing, then the next thing you didn't think about has to be changed. And on and on.
Anyhow, "too many cooks spoil the broth". Later
Hm, e-brake for mechanical disk brake: $16. E-brake for hydraulic disk brake: $209? or it would probably make more sense to provide a trip wire, which is only $39 - but I bet not one ebay kit supports hydraulic brakes either way.
It is very common to run those older frames 24 on the rear to give them a more modern geometry. We do it without a motor, but with one it does improve them even more. As for hitting pedals on the ground, one inch lower on the rear could only do that to a bike that has a very low BB height. Obviously this is not the case with any MTB, old ones especially. The next generation of Trek after his one was one inch lower already, and the new ones another inch yet.
I agree that no ebay kits, and most kits anyway, are not supplying an inline switch for hydro brakes. 39$:by the way. For 150$ you hsve the complete Magura MT5e brake with switched lever.
markz said:
Isn't that the case for everyone here [strike]in[/strike] at E.S.
Not quite yet for me. But I have collected two other motor hubs and I've used my experience to help a friend get his Chinese Hummer knockoff up and running again.
One thing I would suggest is that if you are on a truly tight budget, allow for an expected 10-20% for misc. expenses you didn't think of.
I would add that while I got my bike functional in a matter of a week or so, I spent most of a year learning what I really wanted it to do and making the appropriate modifications and additions.
Agreed to MadRhino's point that this will likely not be my last bike. I can imagine I won't know what I want until I'm regularly riding. That's part of the reason that I don't want to break the bank on this build. But, if that means selecting a frame with a clearer upgrade path later, I would certainly be open to suggestions.
Motomech, all I meant by the 30 MPH comment was that I don't see myself wanting to go that fast, so I can't imagine needing a bike that I can upgrade to hotrod status. I don't want to go 30mph at this point in time, topping out around 28 mph with hard pedalling and cruising mid 20s seems right for my temperament. This makes me think the Fuel 80 is a suitable frame, unless there are other upgrades besides speed that would make the bike unsuitable. This is really only a commuter for me, not for trail riding, off roading, going crazy fast, etc.
Wturber, do you have another build in mind as you're collecting? Or just picking things up on the side?
Sorry, Donn, in all of these posts I think sometimes I am not clear in what I am referencing. The ebay motor that said it was vbrake compatible is this one here: https://www.ebay.com/itm/ebikeling-...-Conversion-Kit/312058788232?var=610800250059
OK, that's the one I was looking at, so ... sure, it most likely is, but it doesn't really say so.
The Trek has an aluminum frame, so plan on one or two rear torque arms. Why not consider a $200, 1000w, 48 V, DD rear hub kit and a mid-90's steel hardtail (dozens for sale where I reside for $200 or so). Then, with a 52V battery you'll have 33 mph or so available. I put a bike together for $600 plus donor three years ago and it still runs as well as when I built it. Also, look at similar builds on ES. Some have 15,000+ miles on them. The kit was YESCOM; I'd say where the battery was procured, but don't want to start a range war.
I like this, but not because of the 33mph potential - I don't know other people's experience, but in practice I just don't want to ride at the upper limit. The conditions aren't good. I'm not swaddled in armored clothing and a serious helmet, like I would be if I were riding my motorcycle. I'm on a light, flimsy contraption with narrow tires. The road isn't in perfect shape. The route is infested with motor vehicles that massively outweigh me, can go much faster and aren't expecting me. I get dust in my eyes. Whatever. It isn't fun, as a regular thing anyway.
But I do love to be able to pull out and be on my way, quickly if necessary, and that's when the dial can go up above 700W.
Aluminum rear triangle? Hm, hope at least the dropouts are steel?
I picked up one motor simply because it was in town and was only $25. I figured I'd either find a use or run across someone else who could use it. The other was a Q100 that I bought from Motomech. At the time my thinking was to make a lightweight, low assist road bike in the vein of Chas58 and others. But I'm much less sure now. I road to work on my Trek 1400 to gain perspective on the real differences, and it kinda hit me how insane the road bike drop bar riding position and skinny tires were for the purpose of commuting. Frankly, my subjective feeling right now is that skinny tired road bikes are kinda silly. This, after riding that bike many thousands of miles over the years on that kind of bike.
So now I'm thinking I might electrify my old Dahon folder just for grins. But no real plans though. I've got my bike dialed in for commuting and I'm pretty happy with it.
I shopped out the BBS02, 48v dolphin battery and basic charger. price came to 888.95. Of course, that's not including tax and shipping so $1000 is about right. Personally I'm riding the BBSHD with a 52v 14 ah battery. I can hit 36 mph when fully charged on flat, but I rarely exceed 28 just for legality here in CA.
IMHO there's nothing like the control of pedal assist, the shift-ability of having a mid motor and the complete and total lack of noise. My old 9c rear motor was a constant struggle with truing spokes, heavy on the rear end and a mess of wires on brick lipo. 18650 packs are just awesome. My kit, after what seems a hundred little purchases, has pushed me to about $2000 but I'm so in love with my bike, I get the best.
Going into the maintenance and wear issue, so far, at 1k miles, my only maintenance other than charging the battery has been general bike stuff (tires, tubes, chain lube etc.) Also I pulled reduction cover off to add grease (15 minutes). I figure that Ill pull the motor apart soon to re-grease the worm gear and add better water-proofing. (An hour or so. Lots of videos online to show how this is done and it doesn't look difficult). I expect the chain to wear more due to the amount of stress placed on it but chains don't cost much, same with the gear clusters.
On my old, cheap DD rear I was constantly messing with the spokes. Having a massive rear hub puts the spokes at extreme angles to the rim and due to their shortness caused weird bends and cross-overs. I rebuilt the wheel completely twice and broke at least 8 spokes during its life.
Tires are going to wear faster just due to acceleration on either style of motor, live with it :)
I helped my friend build his electric. He was impatient and wanted something cheap and NOW! We found Cyclotricity and his kit came out to $550. 36v 16ah on some random 750w controller and rear hub. https://www.cyclotricity.com/. He's happy but not really enjoying the 21-22 mph top speed. Now he wants to upgrade his controller and battery for more speed.
https://www.empoweredcycles.com/collections/performance-e-brake/products/tektro-dorado-hd-e710-e-bike-hydraulic-brake-203mm-front
$150 per brake for top-o-the-rainbow hydraulic e-brakes
Agree with this. The small rear wheel is bad advice. OP wants a pedalec of modest power, not a motorcycle. Rear suspension on a commuter is not required even at 30 mph and rear suspension corrupted by the wrong rear wheel is a move you may regret and for certain you will never appreciate. Keep it simple.
Keep in mind what the OP said at the outset, " If I were to deviate to all bike paths, it would be 20 miles one way. Both routes would be very flat, on paved roads with a fair amount of bad quality cement and potholes (more on the road than the paths)."
Required? No. Perhaps worth considering? Certainly. A suspension seatpost might be a compromise option worth considering.
Yep, my recommendation was a hard tail DJ. I find for those speed averages and low budget, a robust hard tail with a good front suspension is making the best build.
I have found an old Santacruz Chameleon for 500$. This bike can crash 3 times a day, yet last 20 years. It is easy to make custom dropouts for it, and its frame shape is making for easy geometry tuning. There are many old DJ’s that are still in perfect shape, because very few riders are abusing them to the extreme stunts they were built for.
Sure, but if he slows down on paths then it's less justified and it's not clear that his paths are rougher than the streets. We can talk in hypotheticals but we don't really know, you may be right.
My bike easily does 35 mph using PAS but conditions really don't allow those speeds. I have a 40mm travel gravel fork and a Cirrus seat post on a hard tail and my next bike will be ditching the seat post. I commute in Austin and FS would be of no benefit to me at 30 mph. I have a converted FS bike as well and I've commuted on it so I'm aware of the differences.
I am absolutely convinced that a properly functioning hardtail can be counted on whereas who knows about a 15+ year old used FS bike. MTB equipment is not meant to be cornered on pavement at 20+ mph, my previous ride's fork shuddered and buckled under side loads present due to the grip and speed that pavement + electric provides. If it needs to be cheap, only get what you need. That fork, BTW, was brand new and quite expensive but was not intended for pavement use, just like these bikes being recommended.
Lost in all this is that MTB suspensions are not made to provide a smooth ride on pavement at high speeds plus older, used MTBs are primitive by today's standards and their shocks will be old, poor and possibly worn as will their pivots. When building a first commuter on a budget, the goal should be to maximize the likelihood of success and taking pot luck on an old used suspension and modifying it blind for questionable reasons is really not the way to go about it.
There is merit to DD hub drives from a standpoint of low maintenance, but there's really no doubt that a Bafang mid-drive on a hardtail is the easiest and most likely successful conversion for a first timer while meeting budget and performance objectives. No external controller, less complex wiring, no worries about dropouts or torque arms, no problems fixing flats on the road, no concerns over wheel build. It's a no-brainer even considering maintenance. A successful project is better than an unsuccessful one.
I'd say find a hardtail THAT FITS properly and is serviceable, perhaps even with a rigid fork, and that takes at least a 40mm tire and disk brakes. Then add a BBSHD and a good battery. That will do it, provided he invests some time fixing the terrible stock PAS programming. Then after using it a while he will better understand his needs and what he really thinks is best long term. Then he'll know if he needs FS and more/less power.
