999zip999
100 TW
I seen a working rear hub one with a 9c going 40mph on lipo. Everyone love it.
999zip999 said:I seen a working rear hub one with a 9c going 40mph on lipo. Everyone love it.
Trikes should be slow. It's better that way.
This has been discussed several times on the forum, and as suspected has proved not to be a problem by a tadpole trike that was fitted with two hub motors. I didn't search for that thread, but I did follow it at the time.may be I am stating the obvious but with two motors, it seems that you are going to install them at the front.
How do you keep both motors running at the same speed when going straight and at different speed when cornering?
Arethosemyfeet said:Was about to place the order, then found mention of the width of the q100h - apparently it's 135mm+ which is obviously a non-starter with 100mm gap to fill. Back to the drawing board, it seems.
Arethosemyfeet said:And this is the point where I look hugely embarrassed! I've been convinced the whole time I've had this trike (3.5 years and counting) that I had disc brakes. Having only had rim brakes in the past I hadn't seen anything to disabuse me.![]()
It was only when I went and checked the original receipt that I realised that, while I had paid for a brake upgrade, it was merely a higher class of roller brake (the Shimano IM70) and not disc brakes. I should have twigged when d8veh mentioned it previously. Apologies for the confusion. In any case, that makes it pretty clear that the Q85 is the beastie for me.
