Futterama
Hi forum,
I'm totally new here, I need a place to get help with my brushless motor.
I have this brushless RC motor: http://www.skyrc.com/index.php?route=product/product&path=39_48&product_id=141
I'm building an ESC for it and I'm trying to understand the motor and how it works. It is a bit different from the other brushless motors I have (1:10 RC scale motors) and there are some things I'm wondering about.
The goal is to add hall sensors to the motor and control it using a PIC microcontroller, MOSFET gate drivers and low RDSon power MOSFETs.
The motor data I could figure out that the manufacturer didn't give:
Rotor: 4 poles.
Stator: 12 slots.
Winding pattern: WYE.
The first thing that makes me wonder is when turning the motor by hand, it has 24 "positions" per revolution. Given the motor data above, I would expect it to only have 12 "positions" per revolution. What am I missing here?
I'm suspecting an inaccuracy in the rotor poles because when turning the motor by hand, one "position" at a time, I feel that the rotor jumps easy from position 1 to 2 but from 2 to 3, there is more resistance. From 3 to 4 it is easy again, and then more resistance again from 4 to 5. It's almost like position 1 and 2 should be one position and not two, then giving a total of 12 positions as I expected. Am I on to something here or is this totally normal? The power wires are left unconnected during this "test".
I also did the above test with 2 wires powered (from the lab supply through a power resistor to limit the current to 4A) and this is the same result, the motor can be placed in these 2 positions, but if I force it a few positions away, it will jump back due to the lightly magnetized coils.
I made another test on the motor. I hooked 2 power wires to my cheap handheld scope and turned the motor using a powerdrill at 1200rpm. The resulting BEMF waveform is attached. I does not look like a perfect sine as I would expect. Another evidence of a rotor defect?
I hope you guys can help me figure out this motor.
Please let me know if I should post some pictures of the motor internals.
Best regards,
Martin
Rotor: 4 poles.
Stator: 12 slots.
Best regards,
Martin
