Doctorbass
Bob, Fechter or any other that could help me to desing a current limit circuit for my DC-DC modules charger PLEASE HELP!!
Here is the situation:
-The DC-DC modules that i have can give between to 170A in short circuit and they are built to give stable and continuous 30A at 5V
-They have a internal current limit protection.. but if i use directly these modules on a fully discharged A123 M1 cell it will give the 30A and up to the cell and damadge the cell.
-I will use a 0.01ohm resistor in serie with each indemendent DC-DC output to monitor the current.
What i need is to limit the current to 15A wich is safe is i use Xs 2p or more pack.. that could give 7.5A per cell .
Now 15A would give me 150mV on the shunt resistor to say to the circuit that the 15A limit is acheived.
What i know is that i can control the output voltage using a resistor or potentiometer connected between the "trim" pin and the (-)out
And also i can control the output voltage with the sense(+) and sense(-) feedback pin.
These feedback sense pins are used to compensate for the voltage loss in the wire of the output so if the setpoint of the trim resistor is let say to 3.6V and that the sense pin read 3.5V at the end of the wire (on the load) the internal circuit will overboost the output to acheive the 3.6V at the load where the sense feedback are connected
What i think is that if i try to boost the voltage on the sense feedback pin with few milivolts higher than the preset voltage, the output voltage pin will decrease to compensate because the sense read more than the preset. So by using this method, i think i could control the output current by playing with the voltage control pin like "sense" or "trim" and limit it by this way.
Now what i wonder, is what could look like a circuit that will take the few 150milivolt of the shunt and stop the current to 15A max by using the trim or sense input pin to control this current?
Could it be a simple circuit without the need of using comparator or amp-op.. i would need to built 12 of those.. :lol:
Doc
I need CC-CV of 15A 3.6V...
Doc
