[url said:https://moto-station.com/scooter-station/essai/scooters-electriques-govecs-go-s1-4-go-s2-4-et-go-s3-4-2014[/url]"]
Batteries
Assembled in Taiwan, the Lithium Polymer battery of the GO! S2.4 (+) and GO! S3.4 weighs 32 kg. That of GO! Removable S1.4 weighs only 17 kg. In the pack, there are no less than 440 Samsung / Panasonic cells, arranged in several layers. The structure of the battery is the subject of a patent filed by Govecs. The cooling of the cells is ensured by an adequate arrangement of the latter. In addition, the pack would be particularly airtight and therefore protected from humidity or dust. It would accept micro-charges (no memory effect) and its lifespan is given for 1000 recharging cycles, ie 50,000 km minimum, indicates the manufacturer. A warranty extension is possible on the battery, after the 2 years manufacturer's warranty linked to the vehicle. It is billed 100 € the 3rd year, 150 € for the 4th (prices excluding VAT). To make this accessory last, Govecs indicates that it must be fully recharged at least once a month.
Thanks for the reply. The nominal system voltage is 72 volts for the battery on this scooter. I'm not sure of the controller current limit. However there is a 70 amp fuse for the lead coming from the battery. I don't think the controller current limit would be above the limit of this fuse. Likely it would be lower for a safety factor. Going with 72 volts x 70 amps would be 5040 watts. If I do the same calculation with 84 volts when the battery is at full charge the wattage is 5880. So I'm figuring the maximum wattage is in the 5000 range. Would the controller limit be on a label on the controller?What's the controller's current limit, and the system voltage? That gives you the wattage it is capable of, which should match that of the motor, for a system that was designed to work as a unit.
Thanks for the info. I looked on the top of the controller but I did not see a label. However I did a google search and found a listing on the bikez.com web site for a 2012 Govecs S 3.4 scooter. Most likely the 2014 model I have is the same rating. The rating listed for the motor is 4.5 horsepower or 3.4 kW. I should have guessed it with 3.4 in the name.The controller should have a label on it that gives it's ratings, or a model / brand that can be traced to specs somewhere.
Alternately, you may find ads for the scooter model itself that provide "ratings", or info from manufacturer pages (current or archive.org)
I found out the controller is a Sevcon 4th generation size 4 model. It has many ways that it can be configured.Thanks for the info. I looked on the top of the controller but I did not see a label. However I did a google search and found a listing on the bikez.com web site for a 2012 Govecs S 3.4 scooter. Most likely the 2014 model I have is the same rating. The rating listed for the motor is 4.5 horsepower or 3.4 kW. I should have guessed it with 3.4 in the name.
I don't have a recommendation for Atlanta. I'm in Austin, TX. I retrofitted my Govecs S 3.4 with other battery packs. I series connected a couple of 36 volt batteries to get up to 72 volts nominal. I also took apart the original Go-tech Energy battery and bypassed the BMS inside of it to get it to where I could charge and use it to power the scooter. If you can find another 72 volt battery with similar specs to the original battery and mount it in the frame that could work. However I am not using the built in charger. I'm using an outboard charger of 84 volts to charge my battery packs.Can anyone recommend how/where to get battery repair / replacement in Atlanta? If my post should be placed elsewhere please direct me. Looking for someone or somewhere who can help, paid of course. Thanks.
