Transit Artist
🔋 Established
After fixing a flat and reinstalling my rear/hub wheel my motor won't start. Bike has power but seems to only provide spurts to the motor. Ran through the wiring and found some points of interest I'm hoping for guidance with. Initial sputtering: here the green LED on the Superharness seems consistant and was before...
My wires were badly crimped and will be rewired and reconfigured immediately. But is it the problem?
and my new connector blades seems to be sparking and singeing more than it used to. I've been sliding it in real slow after chipping my old connectors, (no on/off button on the battery), if that makes a difference...
After straightening the wires (and checking for all loose connections) I got the same response but now the Green LED is flashing. Did the un-crimping change something?
