Help with selecting power supply
dolby
Melbourne, Australia
I have this Turnigy Mega 400W charger. I need a power supply to suit must be greater than 15v up to 17v to be able to use the max 400w of the charger. Any recommendations? I am looking at the cheapest option available.
Will a 400w power supply be sufficient.
Would this be a good option:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=28832
Should be ok, but I have not heard anything about that particular PS being reliable or unreliable.
Many are using a Meanwell Switching power supply of some kind, and imitations of the same can work ok. Not sure which model meanwell you need, but you would need more than the S350 that is commonly used. Only 350w. Some headroom would be advisable, like 500w for your 400w charger.
The meanwells come in many wattages and voltages, so you should be able to get one just right for your charger.
