Thanks and yes other then the shaking (which needs a different encoder or something added to the code) its running awesome. I even just got the speedo partially working.HighHopes said:thanks for the share and discussion, really neat to see! i like how the regen works, just take your foot off the gas? now i understand why you spend so much time tuning it.
this is all going so well, now lets see some burn-out vids!
fechter said:You might consider putting a sensor on the brake pedal for regen input. Having a slight regen at zero throttle is nice and simulates engine braking in a normal car. Going to a higher level of regen when you touch the brake pedal makes it intuitive. This is how my Honda hybrid behaves. I find it's nice to have a coasting mode that doesn't require much driver skill.
fechter said:I see.
I had a scooter set up like that once, but I didn't really like it since instinct is to totally let off the throttle in many instances and it would go into full braking. I preferred having it go into a coasting mode when I let off the throttle.
On the Honda, if I press on the brake pedal just enough to make the brake lights come on, it goes into strong regen but this is before the friction brakes make contact. Same setup on my bike. It's activated by the brake switch.
I suppose it's a matter of preference and a learning curve.
Its built into the ACPL337 chip.izeman said:How do you do desat control?
Arlo1 said:I have no cooling hooked up even yet.
I found it would not spin the tires after so I think repeated back to back runs will require cooling.
Lebowski said:Arlo1 said:I have no cooling hooked up even yet.
So you have no cooling yet for the IGBT's other than just the alu they are attached too ? I mean nice they can run so much current without cooling !
And you had the accelleration limiter on ? I think I still hear the tires slipping though ?
Did you have a look at the battery voltage ? Maybe the LVC came in ?
Anyways, cool results a rolling burnout halfway through the run would have really put the opponent in his place but would have costs you the tires....
Arlo1 said:Next time out I will turn the power up with warmer batteries and put the slicks on...
Thanks Doc and 3 years.... Since I started this.Doctorbass said:Really Nice work Arlo and thanks for posting a video of a race! it's been about 2 years now that you are working on that project, thats cool to see your first race!
You really must race in the NEDRA!! i would be curious to see witch category you would be in.
Beating gas is too easy now... your next step is beating electric!
Here are the actual record holders: http://www.nedra.com/record_holders.html
Doc
Arlo1 said:Thanks Doc and 3 years.... Since I started this.Doctorbass said:Really Nice work Arlo and thanks for posting a video of a race! it's been about 2 years now that you are working on that project, thats cool to see your first race!
Doc
It would be SC A4 or A3.
I don't see any competition for that level as right now its in the 12s Soon 11s and 10s are possible.
More to come I am just getting started.
Arlo1 said:Vbox would be cool. I tried useing my phone but the refresh rate is 1hz for the gps.
I have a app that uses GPS and the accelerometer so I will try it.
Need something for Android no iphone....
Doctorbass said:Arlo1 said:Vbox would be cool. I tried useing my phone but the refresh rate is 1hz for the gps.
I have tried these for android but i found none to be very accurate
best is to get a used Vbox from ebay...
Arlo1 said:For those of you lookign to build these I am trying to work on organizing the first page. I am trying to get some of it done every day so keep you eyes on page 1....
Arlo1 said:Hooked up the liquid cooling today. Controller and motor stay icy cool. Turned the Battery amps up to 550 and the feild weakening up to 450 amps Still have the Phase amps set to 650. At a full charge it sags about 60v which is not bad. 410x550 is a LOT
Anyways I will try to get video soon it the rain I can do the $100 bill trick and at 110 with the same tires it spins at 110km/h
I only origanly planned for this much power and that was with 1MBI800U4B-120 IGBTs and Right now I am running 1MBI600U4B-120 IGBTs which are rated for 25% less at 80 deg C....
Soon I will put the more powerfull IGBTs in and crank it up some more!
