recumpence said:More bling!
You can see CNCAdict's 40mm motor here along with some more drive pics. Also shown is the secondary chain drive adjustable idler.
I have almost all CNC machining for the first 12 drives completed. There are frame/swingarm mounts to be made yet along with the FW adaptors.
Fun, fun, fun!![]()
Matt
dimitrib90 said:Does any think that one of these RC motors could have enough power to run a motorcycle?
GGoodrum said:recumpence said:More bling!
Fun, fun, fun!![]()
Matt
I just wet myself a little...![]()
Can't wait!
recumpence said:For old guys like you, they make products for "Bladder control problems". :wink:
recumpence said:My products are designed to cause drooling.
C'Mon, Gary, after a comment like that, you gotta expect me to have some kind of come back!![]()
recumpence said:Glad to like shiney bling!
There will be a plastic or rubber wheel mounted to the idler bearings shown in the pics. Other than that, the FW adaptors and frame mounts are all the is left to make. I know these will sell quickly. Run #2 will be a lot quicker to make due to R&D being finished. All what would be required is a week or two of Dave's time to run the HAAS for more parts.
Matt
recumpence said:Yup, it clamps to the output shaft bearing tube. The top of the mount is "T" shaped with holes tapped in the sides to either screw or weld to the frame.
Matt
recumpence said:The mount is 1.125 thick and 4 inches long at the top of the T. There are two 1/4-20 holes tapped on the sides of the T that are 3 inches apart.
If this is to be mounted to a tube, and you do not want to weld tabs, you would use U bolts. I have been considering having a V or U shaped profile machined the length of the T at the top so it can be layed against a tube and automatically align with that machined groove.
Matt
GGoodrum said:recumpence said:The mount is 1.125 thick and 4 inches long at the top of the T. There are two 1/4-20 holes tapped on the sides of the T that are 3 inches apart.
Matt
I'm guessing 99% of us do not have an easy way to weld tabs on a tube, so the grovved channels will be a welcome addition.![]()
So what is your estimated cost for the entire setup? I haven't followed all of this, but it's looking good.recumpence said:It looks like $11 each for manufacturing is the final cost.
recumpence said:The ball is rolling on the FW adaptors!
I am sending Jason a White freewheel for thread fitting purposes.
Matt
Miles said:How about the option of two shallow 90deg. grooves in the gearbox shaft to match the point profile of a set screw type, or even just two flats?
recumpence said:That was my thought as well. Two setscrews with two shaft flats.![]()
Matt
