recumpence
1 GW
Yes that FW only works on the smaller thread. So, it is a no-go.
Matt
Matt
recumpence said:Wow, quiet lately!
----Insert cricket sounds here----
Only 5 of the first 12 are spoken for so far.
Hmm, I'm glad I didn't make more than 12 to start with.
Who else wants one?
Matt
deecanio said:Hi Mitch,
your drive wont be very good i'm afraid Mitch, your concept isn't bad but your choice of materials leaves a lot to be desired :lol:
deecanio said:why don't you post us a few good shots of your swingarm - we may look differently at the problems and come up with something?
D
MitchJi said:For my first version I copied Matt's original Ebox design using gears instead of belts/chains and it worked fine :lol: :
I figured I could copy his new design using similar materials. But that was a model. For the production version I plan to upgrade from Pine to Locust or Oak with Schedule 40 PVC shafts.![]()
MitchJi said:I plan to upgrade from Pine to Locust or Oak with Schedule 40 PVC shafts.![]()
recumpence said:OK, I am nearly finished with a couple drives. I have done face plate machining, shaft manufacturing, bearing seating, and I am now doing final assembly.
For those who want a drive, there are still a few available. Gary will have his pretty soon. The next few will trickle out as I recieve the remaining bits (special belts, pulleys, etc).
Matt
I still want one, but I need to figure out the numbers for gearing.recumpence said:OK, I am nearly finished with a couple drives. I have done face plate machining, shaft manufacturing, bearing seating, and I am now doing final assembly.
Matt
recumpence said:I would say it would be best to go with 5 to 1 ratio, then 2.5 to 1 to the wheel. That would give you the power handling you need with the reduction you are looking for.
What part of Indiana are you in? I live an hour northwest of Chicago.
Matt
recumpence said:I can send you a drive and wait on the exchange rate to improve. :wink:
Matt
Gary's finished drive................
It looks like a 1900s steam engine.
Matt
Our cold rolled steel shafts are fully keyed along the entire length, and may be purchased in lengths of 18", 36" or 72".
Finish is flat, non-polished for regular use. Diameter tolerance +.000" and -.002". For maximum durability, we recommend your shafts be hardened by a heat-treating service once you have cut them to length and done any further machining.
Shaft Dia. 1/2" Price/in.$1.04
TruKey® Shafting from Keystone is designed to provide the straightest, most accurate pre-keyed shafting in the industry. We stock keyed shafts in the most common diameters with standard keyways, and can provide it cut to any length up to 20'. TruKey® shafting is available in turned ground and polished carbon steel for an accurate diameter as well as 1018 cold finished steel and turned, ground and polished stainless steel. All keyed shafting has chamfered ends for easy installation.
Keyed shafting is available in lengths up to 20 feet and diameters ranging from 1/2" to 4 1/2".
Shafts commonly available in round, hex, or keyed shafting in every grade and tolerance the world has ever known. They typically come in lengths of 12, 36, or 72 inches and can be cut or filed for use in applications. Special milling is available.
http://kmac-distribution.com/shafts/hardened-precision.htmShafts - Keyed, Precision, Tapped and Threaded
1566 Steel - Straightness Tolerance .002" per Ft., 12rms Micron Finish, Case Hardened, Rockwell C60, stronger than stainless steel, but are less corrosion resistant.
303 Stainless Steel - Straightness Tolerance .250" OD, .0036" per Ft, .375"-1.25" OD, .0004" per ft, 10-16rms Micron Finish, Rockwell B83
LEE LINEAR's new automated hardening system utilizes a state-of-the-art electromagnetic based proprietary hardening system, to produce the next generation of Precision Shafting. With the new automated hardening technology, a consistent and precise case is accurately controlled by computer. The result is a thinner case as durable as standard case hardened shafting, with the same hardness and load carrying capacity. The LEE LINEAR Precision Case Hardened Shafting is suited for applications requiring long shaft lengths because of its ability to maintain better straightness with reduced distortion. All LEE LINEAR's shafting is demagnetized, and shafting diameters of one inch or less are rotary straightened to remove any kinks, or bends in the material.
Anyone machining case hardened and ground steel shafting will appreciate the product’s ease of machinability!
