It's cool, no worries...I think I'm the silly one here..
I've got a treadmill motor running from an SCR (not a good combo so I heard) and the power needed to be converted twice in order to drive the motor more efficiently. Running at 36v would've limited the motor to 500w or so (iirc..edit; 666w) and it's a 1.5/3HP motor (cont/peak). It's not a normal hub or RC system at all but that's why it appealed to me...
I searched and searched and couldn't find a case of anyone trying this type of combination. It's pretty cheap to build over time too; $50 20ah battery, $80 1kw inverter, $85 controller, $35 motor..so about $250 in the drive system. 2 more batteries will put it just over $350 but then it should be capable of 2HP peaks (and 1kw for sure) so I think it was worth it...
I have no idea of the range or durability yet. It may really suck or I might be able to hypermile and get pretty far. The inverter draws 6w idling and is 87% eff max..but it actually requires more like 12-15w since I have to run a small incandescent light as well or the inverter chokes. The controller is around 98% eff and my gearing may be 80-95% eff...I forgot what brush motors are, like 90%? Total efficiency wasn't a real goal tho..I kinda just wanted to bump my rep with the stats...
Why do I need a motor that can peak to 3HP in a push trailer? Will I ever want to go the 45mph that it's currently geared for?..no. But being able to honestly say that it's capable of pushing 2HP will be really, really cool. That's the power of a 2-stroke pocket bike...in a push trailer.
I think I'll probably use the sign amberwolf posted and make it the biggest. I want to add others too though. I think under a big "High Voltage" sticker I'll put a little sticker w/ more detail..maybe "AC: 110v/18amp peak. DC: 180v, 9.2amp peak". If I can work it into one sticker I might do that too. I need to get a couple for the controller too but I need a real box for it first. I may mention the low voltage DC on/near the fire hazard sticker..not sure yet but I want it all to be neat, logical and fairly complete.
I'll probably add a big "1000w" sticker too..looking at the details you could figure the real power potentials but it's what the motor is fed that really matters as far as I can figure..so if I got a ticket based on the numbers on the stickers it might be easy to refute..they'd have to actually test it somehow to be sure, which they have no right to do as far as I know and the controller output is adjustable anyway. Enough of my rambling for now..have a good one.
