These are rated at 130C max http://thunderpowerrc.com/html/G6ProPower65CSeriesBatteries.htm
However, they are also ~ 2 times the cost compared to nano-tech's.
So to get 3000 amps burst (1500 Continuous) out of the Thunder Power's would be $1199.97 (23.1Ah)
For the same price and voltage you can get 5400 amps Burst, 2700 Continuous (60Ah)
And these are just the rated discharge abilities, a few forum members have found them capable of discharging more than the rated number.
at 100C that would give you a 6000Amp bust pack for $1199.97 at 22.2V, just scale accordingly to your voltage needs.
In addition you can charge the pack at up to 10-15C, aka whole pack from 0- >90% charged in ~4-6 min.
It would also be smart to order 5-10% more than you need so you can cherry pick the most capable batteries, as there is a good chance at least once pack will have a bad cell in a large order.
The best place to order them is directly from Hobby King, it's best to be a bit patient when you order these, so if you don't mind waiting on them to be shipped from china, there is a good chance you will get the best deal for large orders. Otherwise the local warehouse is always a good option.
Here is a few demonstration/discussion threads:
http://endless-sphere.com/forums/viewtopic.php?f=14&t=22464
http://endless-sphere.com/forums/viewtopic.php?f=14&t=22441
