I received this http://eclipsebikes.com/48v-bms-16-cell-60a-p-1042.html BMS today. I thought it was fairly straight forward to wire but I think I may have blown it. On the board are the following connection points and what I think they mean.
P- Power neg out to controller
B- Battery neg into BMS
C- Charger neg into BMS
P+B+C+ Common connector for the pos leads to the controller/charger/battery pos.
There is a 15 pin connector for what are the balance leads I assume these go on the 15 series link plates between cells but i've no idea what order.
My battery is a 16s 1p 10ah headway pack so what I did was connect my battery neg to connector B- battery pos to B+C+P+ terminal. I measured the voltage at P-B+C+P+ and got 55.5. I then connected the 15 tails to the 15 plates in sequence based on my pack order. When I plugged the 15 pin connector into the board the first and last resistor glowed red hot, i unplugged it within seconds.
Now with the battery pos and neg still connected to B-/ B+C+P+ when I measure the voltage at P+P- im getting 44.5v but measured at the battery its still 55.5. I dont know if its a coincidence or what but if I divide 55.5 by the number of fets 7 and multiply by 6 I get 44.5. Is it possible a fet is dead? Would it cause my voltage drop if it was? Did i mess up somewhere? The resistors all still seem to work and have the same measured value despite visual damage. I only noticed afterwards the second fet is marked (T470 BN1C3N). The other 6 are marked (T470 BV0Y2E) dont know if thats significant.
Whole board showing damaged resistors
http://imageshack.us/photo/my-images/545/photoau.jpg/
Fets
http://imageshack.us/photo/my-images/684/photo2dt.jpg/
Shows second fet is different to the other 6
http://imageshack.us/photo/my-images/221/photo1vtm.jpg/
I cant seem to find any info on the site or indeed the net about wiring a BMS. I hope someone can offer suggestions or its €50 down the drain.
Fets
