Remember the NV input is not so much "power"-limited, as "torque"-limited.
As long as you don't exceed the torque limits at it's input (meaning, you gear the input to it based not on the speed you want out of it, but rather the max torque your system is able to put into it), it'll probably survive fine up to the actual power limitation of whichever version you get.
Alternately, you can limit the max torque output of the system prior to NV input by limiting the current to the motor (via controller settings), based on the motor's torque output vs current, and your gearing ratios needed for the speeds you're after, etc. THat method means you aren't limiting your *speed* via gear ratios, just limiting torque input to the hub to below the NV's limits.
FWIW, one other difference between the NV and the SA (and other IGHs, probably not including Rohloff) is that at least some of those IGHs suffer from "lash"-induced stresses, when the gears are not fully meshed and then high motor torque is suddenly applied, slamming the teeth against each other. This appears to be the cause of a failure mode seen in some disassembly pics of failed units (like in one of AussieJester's build threads, I think it was), where teeth are broken off at the root, and then they can rattle around in the IGH where it is possible for them to get in between other teeth and cause further damage.
It's more a matter of IGH design, and manufacturing precision, than of how an IGH actually works, but since the NV is always in contact and doesn't use teeth, it doens't have "lash" like that. It has *other* potential issues with sudden hard application of torque (like slippage), but those shoudl only happen if it's outside ti's torque and/or power limits.
