maarten_almighty
- Joined
- Jan 10, 2020
- Messages
- 47
Hello all,
My battery pack is 10parallel, 20series (72v nominal) built with Sanyo NCR18650BL cells. They are rated for 7A max continuous discharge, but i could not find any info on temporarily discharging them at a higher rate (for example 10A per cell). Is it acceptable to discharge a cell (during a very short period of time for example 1 minute) at a higher peak amperage than the rated continuous max amperage? (provided the battery pack temperature is being monitored via the bms and as soon as temperature gets over for example 70 celcius the bms cuts the power or more likely limits the power to 7A per cell).
Or is it a bad idea and a no-go to discharge any cell (even temporarily) above rated continuous max amperage?
cell info: http://www.nkon.nl/sk/k/NCR18650BL-specification.pdf
Could you give me an indication of how bad the effect on cell life/capacity would be caused by this temporary higher discharge rate?
My bms can handle 200A but is adjustable (via bluetooth), can adjust max amperage adjusting to current temperature.
Thank you very much!
