When using higher power, even proper torque arms can be inadequate. My first try at 72v 40 amps, I had two ebikes-ca torque arms on a cromo front fork. As I did a throttle test with the wheel off the ground, the axle still tried to leave the dropouts.
Cause of failure? Partly nuts still loose, even though I'd tightened them pretty hard. Partly the fact that the wheel was off the ground, adding a force tending to pull the axle down out of the dropouts. But primarily, a hose clamp is a joke for securing a torque arm for high power. The clamp simply started to slide down the fork. This is possible because the torque arms were a two piece design.
My solution was to weld a plate to the fork, allowing two bolts to secure the arm. Tested to 3500 watts and now rock solid. Nothing can rotate now, or slide down the fork.
Alternative solution, adjust the torque arm to fit your bike, then weld in place eliminating the pivot at the bolt of a two piece torque arm. Then secure with multiple hose clamps, or better still, a thick metal strap and bolt.
We need somebody to start marketing a torque plate kit. Basicly a nice thick lazer cut hole in the center of a peice about 4"x4", for rear hubs. The purchaser can then cut to the needed shape and angle for thier particular bike, using a cheap hacksaw or grinder.
Nothing wrong with offering a pinch type too.
