John in CR
100 TW
I'm getting one of these done up for myself for testing, but I'm trying to gauge if others might be interested, since it requires special made shafts for our use. Here's info I have so far.
3 phase brushless outrunner with hall sensors.
Recommended voltage 36V-84V
Maximum current 40-50A
Weight - 2.5kg approximate
Dimensions - 13x13x9cm for the main housing with attachment points and drive shaft extending past the 9cm length of the motor, which is relative to our bikes' width. To me it looks like there's some wasted width from another implementation that could be trimmed.
Kv - 40rpm/V
Slot count 18
Pole count 8
The motor is ventilated with a 50cfm claimed air flow, so I think the current ratings may be conservative for peak, since the same basic motor in a sealed housing runs a 20A controller, but the proof will be in the pudding. Personally I'd like to see it do 60A peaks and 30-40A continuous, since that's the lowest fun tuning of my main bike, though at 9kg less weight I might accept less.
If there's enough interest I'll look into quantity pricing of the shaft I'm having made for mine. What kind of attachment point and maximum diameter would be a good standard, because the bearing inside a hollow shaft means a much larger than typical diameter for RC type rigs?
John
Kv - 40rpm/V
Slot count 18
Pole count 8
John
