ebike11 said:Yes I believe the contrast is pin 3..where would I get that kind of pot switch?
I never ever seen or used one in my life
Thanks for your time!!
Gregory said:Well it uses a standard 1602 LCD display so check the resistor/pot on pin 3 (maybe 2 to 3K ohm?).
You can try using a 10K pot to test if it dims.
dnmun said:yes, that would work. pin 1 is ground, pin 2 is Vcc, pin 3 is the reference voltage.
looking at the power board of mine i have torn apart, which i think is an old turnigy, but they are all the same almost.
between pin 2 and ground on the pcb is a '116' labeled surface mount and another in series in the divider is labeled 01B which i do not know how to decode. i measured it with my meter and got 777 ohms and the one labeled 116 is 735 ohms.
Vcc is 3.3V so that should give you an idea of the voltage range where the contrast feedback is ranging. so what they are doing in that video is putting the trimpot in parallel with 1,2,3 with the wiper on pin 3.
i will try to find a 10k trimpot and see if i can do something similar since i have a meter i have open here already.
ebike11 said:Hi there how are you?
We had posted in a thread awhile back about the contrast with the GT Power watt meter here:
I recently got a 10 pot
http://www.ebay.ca/itm/2-x-10K-OHM-TRIMPOT-TRIMMER-POTENTIOMETER-3296W-3296-/250852988345
It has 3 prongs and 3 wires are needed to run to the watt meter.
I was wondering, would you know, does it mater which prongs on the connect to the VSS/VDD/V0 (that is what is labelled on my meter), a certain order?
Or can I run any combination from the pot to the meter?
Thanks for your time!!!
