EstebanUno
- Joined
- Feb 23, 2011
- Messages
- 38
I've been poking around the board for a week or so soaking up information, and I remain unclear about how to calculate how many amps are drawn from a battery at different loads. Hence my first post.
I'm trying to calculate how many amps are drawn when a motor is run at an efficient rpm with varying loads. Assuming the motor is running at an efficient 80% speed, the load can vary based on grade, wind, pedal assist, etc. For example if the output power required to maintain a speed of 25mph is 400 watts (let's just assume for the example that 25mph yields an 80% efficient rpm), and the system is 36v a simple calculation yields 400/.8/36=14 amps. Roughly speaking, is it as simple as this? Can I just plug in the output required to estimated amps drawn, and then judge how many amp hours my battery should yield?
If so then with a big tailwind, the output required could be halved to maintain the same 25mph speed, meaning only 7 amps would be drawn. Or conversely, 28 amps might be needed with a strong headwind or incline. If so, this implies a linear relationship between load required and current drawn, and I'm wondering if that is the case?
Esteban
Esteban
