So I read an article by Justin on ebike.ca that mentions using a zener diode to reduce the input voltage to a dc-dc converter. His example was to reduce 72 votls from the battery to 60 volts, which the dc-dc converters he sells can handle. The diode to use is stated as being a 12 volt zener diode. I read about zener diodes on Wikipedia but the information didn't really help me.
Do zener diodes reduce voltage? How would one connect one to a dc-dc converters input? Does the diode need to be of a certain power handling capacity? If I need to reduce the voltage by more than 12 volts can I use more than one diode?
There are a lot of half-watt zener diodes available on ebay.
Thanks!
Thanks!
