Simonvtr
⚡ Regular
So here is my diagram of my wiring so far.
It flash with the 100b strobe controller when there is NO power to Vcc1 & Ctrl
Turn solid when there is power to Vcc1 & Ctrl
But here is the strange part.
both my 12fet controller & CAv3 has 4.97v for the ebrake line.
If I connect Vcc1 & Ctrl into either the CA or controller ebrake wires the Relay works but the clicking/switching inside is very weak.
So weak that it does not switch. I have to give it a light tap for it to switch from on or off. The little on board led lights fine when power is applied.
Now the Opto relay works fine with just a single 18650 battery which is only charged to 3.9v.
So is it because the ebrake lines is not supplying enough amp to the OPTO relay?
