Leeleeducati
Thanks for these great pieces of info Mac!
Leeleeducati said:Revolt RV160Pro-Short Sample
kiwiev said:I want one![]()
I agree Snow the phase wires look small, so do they have an internal fan?
Cheers Kiwi
Miles said:Why do you need the connection wires to be a larger diameter than the winding wires? They're quite short.....
Leeleeducati said:I once used the word "overkill" on this forum and was shamed by many membersI did do some early experimenting with bottom brackets and chain lines and there's plenty of adjustment in the design to align perfectly with the 148mm. I'm also actually using a rear cog carrier with spacers to align as needed. I'll post a pic, the rear cog you'll see in the pic. isn't the final one. I'm going to have to fab. one that will carry standard 135 or 144BDC chainrings. I thought of 219's but the smaller crank drive cog ends up being too big to get the same ratio, it still might be an option... I'll also post some pics of the dropouts, one is done, the other perhaps later tonight. I'm no machinist by any means so the work while dimensionally accurate could use some bead blasting to match the bike's finish. anyway the build continues.
macribs said:Don't listen to them. A rv 100 would be much less then this frame deserves. If you can find a nice way to mount a Revolt 160 that would be the one of the wildest build this year. And I really think that motor would suit your aluminum frame. Looking forward to see it completed.
