Seya
- Joined
- Feb 27, 2012
- Messages
- 81
Hi guys,
I have a rear hub motor from eBike kit.
I'm trying to use one of Paul's 6 ft Infinion controllers with this motor.
I had to cut the motor cable to access the hall wires so I could graft them to my controller.
No matter what combination of colors I use the hub motor will not operate.. it just shutters back-and-forth.
It seems as if the halls are out of sequence but I tried every possible combination. I even tried different phase combinations although the likelihood of the colors not matching on the phase wires are much less since I think the default green blue and yellow is pretty standard.
The other possible reason I can think of is my battery it's a frame battery from Paul and it's been sitting for quite a while. What a dead battery give this type of symptom?
