steveo said:
i still have to figure out what im doing with my motor..
im thinking modified bmx frame.. similar to lfp bike...
something steel i can weld to
steveo
I just made a steel swingarm out of angle iron to extend the wheelbase and give me enclosed battery area. You'll need great roads for Hubmonster in a hardtail. She's wound for speed with a Kv of 16rpm/volt, so don't worry about trying to set the COG way forward like LFPs Deathbike. You have other motors for spinning tires with barely controllable launches, and trying to push current to levels to achieve that kind of first wheel rotation performance will give you heat problems.
Where HubMonster excels is in efficiency, speed, and silence. I suggest keeping the total load (bike and rider) below 180kg (400lb) for best performance. Low and long and sleek through the air gives you highway speeds with under 100V.
Consider a pair of air scoops like I put on my swingarm for looks that serve a useful purpose by bringing extra air flow toward the motor. Sure HubMonster is more efficient than other hubbies, but when you start pushing 15-20kw into it or 25-30kw, then there's multiple kw of heat to dissipate from less surface area than typical hubbies. Heat is our enemy and our limitation, and it must be considered and respected. Mine is open with fan blades on the exhaust side, so I pull fresh air through and across the outside of the shell for worry-free thermal operation, but that includes mountains, not hills, and a fat rider.
John
