Boy, it looks like I hit a nerve.
It seems we have more controller failures than motor failures. Am I wrong?????
I understand that the usage at low throttle will hurt the controller due to switching losses, etc..
Cost is an issue as AJ points out. From my vantage point, it's like the Astros are the Twin Overhead Cam 32 Valve 400 hp aluminum block V8
that cost $10k. But, I can buy a pushrod small block chevy motor for much less, and have just as much fun. 8)
Castle Setup with 3220. $800 to $900 bones
Turnigy Setup with HXT. $200 to 250.
6 monster fet setup with HXT. $250
I think that GWhy has many excellent points in regards repairablilty, upgradability, driveability, etc. That's a goal I'm shooting for with
the 6 fet I'm putting together, all with monster fets that all told will cost less than a Castle and you'll be able
to run higher voltages. Try modding a Turnigy or Castle to do that. Eventually, there will be something available
without mods. Even the RC controllers are being modded to some degree, although caps are easy.
The size of the controller matters as well. The more thermal mass a controller has, the more heat it can take before it saturates the sink and then
you get thermal runaway on the fets and POW!!!! toast. Miniturization and extreme power density is awesome, but the small stuff saturates faster.
