Hello Recently found this forum while searching for info on regenerative braking, but found lots of interesting information. My "quest" is to build a fast, relatively cheap, fun and maintenance free hybrid scooter. I'll tell about the things I'm planning to implement, I hope you have criticism to come with
I'm using a Gilera Dna as the base of my project. Originally it has a variator - but I will be getting rid of that I think. The engine is tuned with a 70cc cylinder kit and comes in at around 5kW, most likely the power will be toned down - aiming for efficiency.
Supercapacitors. I will be using a bank of 25 boostcaps, each are rated at 2,5V 2600F with 0,7mOhm internal resistance. Total capacitance will be 104 Farads, total voltage will be 62,5 volts. Total energy stored (fully charged) will be just over 200 kJ. 13 kg all in all.
Charging/discharging. The boostcaps has a maximum rating of 600A, but I won't be getting near that i think. A long term, performance oriented goal, is 20kW (60V 333A). Internal losses in caps will be nearly 2kW at this power output. The boostcaps are not, like LiPo's, restricted when it comes to charging. Also, they can't be overcharged - so I can hook as many as i want (before the ESR gets nasty) in series. Charging the caps with regenerative braking is one of the reasons I will use boostcaps - these can handle the rather big braking loads).
Some more numbers. The "moped", including driver, will weigh in at around 180 kg. At 80 km/h, that's 43 kJ. (100 km/h: 70kJ)(125km/h: 110kJ). Capacitor bank at 50V: 130kJ. Capacitor bank at 60V: 200 kJ. Capacitor bank at 35V: 65kJ.
Internal combustion engine. I will be modifying the original engine with, mounting a injection system and a new ignition system controlled by a Arduino or similar. I want this to kick in if the Capacitor bank drops under 50V, charging it up to - say - 55V before it shuts off again. Will probably be user variable ofc. I'm planning on using a small ~3kW ish electic engine to generate electricity to the caps. 60V output, possibly a DC/DC converter between if voltages doesn't match.
Electic engine nr1. This one from hobbyking, 80-100 is my best bet atm. 7kW will give nice acceleration, even tho doubling that will be a second goal. The back of the variator already have a gear system capable of handling the torque produced - question is just what the ratios are. Will figure this out later on This engine will be mounted to the rear wheel. I will be afterinstalling Hall sensors.
Electric engine nr2. Mentioned under ICE engine, will be working as a generator.
Electric engine nr3. Will be mounted to the front wheel. Not the first priority, but this will be better for regenerative braking - especially in rainy weather (rear wheel slip while braking could be a prob). This engine will most likely be the same as nr1. It will need to be shielded from the environment and be mounted on the forks (they are inverted), shouldn't be a problem. Plexiglass could make for a nice view aswell.
Regenerative braking. I've been reading some about it in this instructable. As the revs comes down, the need to step up the voltage will come into play. A step up converter is the obvious salvation, but building this will be a new experience for me.
Who am I? I'm at my first year towards a bachelor degree in electronics/automation, the basics are there - but the experience is lacking.
Wanted; Input
Wanted; Input
