liveforphysics
100 TW
ElectricEd said:WonderProfessor said:...It doesn't take that much electricity to produce H2 from water, right?..."
Bugger all in fact, but the real question is: How much power does it take to release enough H2 to generate enough power to release enough H2 to generate enough power to release enough H2 to generate enough power to release enough H2 etc. etc.
Very soon you'll end up with nothing due to losses in the system.![]()
As a power generation engineer, as well as a geek with a lifetime passion for tinkering with ICE designs, I can tell you exactly why tiny bits of HHO are able to play a large effect on an engines fuel economy. Forget about the energy from the burning HHO, it's an absolute non-factor. Also, forget about operations at anything but low throttle position cruising, unless you have a massive HHO generator.
It's all about flamewave propagation, and deflagration speeds. At extremely small percentages, hydrogen can shift the lean burn flammability limits for an effective burn from ~17:1 (depending greatly on IAT's and fuel particle size), to >25:1. This not only enables an engine to burn much more completely, but to burn more rapidly, resulting in combustion pressure peaking at a more mechanically optimal time for extracting energy though expansion, without the knock related hazards of spark timing increases or the associated increase in paracitic compression losses.
The worse off the engine's fuel atmoziation ability (aka, anything from the big 3), the greater the benefits realized by hydrogen.
For an example, on my Honda Insight hybrid, which uses lean-burn combustion technology from Honda, I was getting incomplete and unstable combustion as I tried to increase the air/fuel ratio, and during winter with cold IAT's, it wasn't even able to enter lean burn mode. Introduce a tiny bit of hydrogen into the mixture, and poof! Economy jumped from 60mpg average per tank to 70+mpg per tank, and monitering my mis-fire counts, I see about 1% of the count i get with no hydrogen. And this is an example with an engine that was all ready very good to begin with.
Best Wishes,
-Luke
