Rix
100 TW
winkinatcha said:"You smell that stink? Thats you because you are the shit!"
Gold!
Joe
Glad you like that Joe. Wish I had more one liners like that.
Rick
Gold!
Joe
Rix said:Wish I had more one liners like that.![]()
Rick
Sokol said:Rix said:Wish I had more one liners like that.![]()
Rick
Something like: Hyena is so awesome that on a scale of One to Chuck Norris, he's Mr T.
Hyena said:Alright you lot, quit pissing in my pocket, this thread isnt waterproof![]()
Speaking of one liners, my favourite quote of late is from iron man 3
"is that all you've got, a cheap trick and a cheesy one liner?"
"Honey, that could be the name of my autobiography"
*BOOM*
Heh
Rix I meant to ask you before, how did you find the rear suspension when you swapped over to the moto rim and tyre ?
I haven't touched any settings on mine and it actually feels better than before. I guess it's the heavier weight but it feels less springy than before. Still plush but less rebound type "boingyness". It's especially nice when you belt over speed bumps etc at speed, it feels much more like a motorcyle. Maybe it's actually the stiffer side wall moto tyres ?
In other news I finally kicked my new black and gold commuter to life last night, took it for a spin up the street and back and the motor was slightly louder than I remember and continued to make noise even when I backed off. I thought it was the clutch at first but what ever it was I actually liked it. Not as cool sounding as the zero but it had a scifi kinda quality to it. I then realised it was the rear brake line was ever so slightly rubbing on the fine almost slick edge of the crazy bob tyre causing the noise :lol: Like the old card in the spokes trick but clipping the edge of the tyre actually gave it quite an electric sound. Ah well, you win some, you lose some![]()
Also in the losing column it seems my avid code brakes that have only 1 ride on them have shit themselves :x
Hyena said:I edited some together but I think I need more footage to make it worth doing properly. Well, to atleast make it look like it's not completely half arsed.
Hyena said:Here's a matrix style test shot I was playing with using my spewcam(tm) and the gopro recording in 240 fps slow mo. I'll probably have a shorter clip of it in the final edit but it didnt turn out too badly IMO
Haha, Love it !. 2013 is turning out to be the year of the bling.Hyena said:I ended up catching the train in and while waiting on the platform I turned around to see half a dozen people on an opposite train with their phones out taking pictures. I guess the gold rims and trimmings negated the subtlety I was trying to achieve in the frame design
Just noticed your build thread, seems we were both working on blinging gold builds!thewmatusmoloki said:2013 is turning out to be the year of the bling.
How about a pic or 2 so the rest of us can marvel at this new machine mate ?
dan974 said:Hey, JAy, is there a reason why you make your calostat cut @110 or 120°c ? (I can't find it in older posts...) the datasheets give Hall sensors range up to 150°C but some labels are only factory tested @85°C, SS41 label F is factory tested @150°C...riding limited @110°C is a little frustrating compairing to the way I used to ride before I cooked my motor...as you said: the guy said, don't bring me one again I won't do it, first and last time ! , too "tiny fingers" work =), he rewind it because he was curious and said if it work he's a real PRO
I found that point beetween 100° and 110°C, but it seems (largely vented) that in like 3 min stops, the windings get down to 85°C while keeping it turn rear wheel up does'nt accelerate the freezing..., but driving it upper than 30km/h allow it to freeze while riding but the fastest is the stop...I don't know about stator, (but I put the CA temp sensor and the controller sensor behind the loops on the hall's side beetween stator and windings...it seems that when 100/110 are reach for a long time, the rotor become saturated too and it seems to me than it's the part who take the longer time to shed,Hyena said:...I also put the thermostat on the stator not directly on the windings so there's a difference in temp from the windings. The windings could get transiently really hot under high load but once the stator gets heatsoaked over 120 it's going to struggle to shed that heat.
the basic fusion point is (185 °C) with some lead+tin(pewter) but I discover that in france it is supposed to be forbiden due to environnement stuffs, so there is the ones silver+pewter (225 °C) so I guess using the second one could resolve the melted solder...and that explain why with some it takes a longer time to melt...I've never had a hall fail from over temperature though I have melted the solder off the hall (and phase) wires a few times.
yes I just using for checking calibration beetween control temp sensor and the CA because I play with the kelly software before playing with the CA...actually I read on the CA and the Kelly cut @ preset sofware temp using a KTY 81/210, I even install an ebay with Big digits ...but I think a buzzer would be so much nicer just a few degrees before it cut or rollback...just to advise...I'm know thinking of a 5000 or CROW to access the unheating world =) I don't know how high I get it but for water to vaporize on the rotor it should have reach 150+...If you have CA V3 like icecube describes then the thermal rollback is a nicer more progressive way to do it.
Hyena said:Yeah Dan I knew that guy would never want to see you again after rewinding the motor :lol:
I typically run a 120oC thermostat to leave a safety margin. If you get a motor baking hot and then cut power the temp will continue to climb. Sure, they're probably right up to 150 odd but I'd rather wait a few minutes for an overly cautious thermostat to kick back in than be replacing a cooked motor. Plus it's good insurance for noobs who may have no mechanical sympathy and would otherwise thrash a motor up hills until plasma melts through the side covers
This is a solution that works on any motor under any situation in the absence of any other hardware. If you have CA V3 like icecube describes then the thermal rollback is a nicer more progressive way to do it.
I guess it should be ok instead of a buzzer, I think it's time to plug the CAV3 =), how's rated the HS40 continous power/amp ? 1500W/2000W ? 40A ? for the temp to stabilize under 100°C ?icecube57 said:... you had plenty of warning .... you can feel it overriding your throttle which shouldd give you notice that you need to back off...
Cheers mate,pendragon8000 said:Good luck with the fitness mate. Intervals of sprint burn more fat than constant effort but traffic will probly do that anyway.
As I tell the befuddled motorbike riders as they pull up along side me and question WTF is powering the bike, I tell them "I am strong, like ox"Samd said:Ha - those well rested legs must have dished out the Newton Meters!
I should have clarified, there ARE options but most are a bit pricey. haha.None of the gold chainrings here would do? Seems to be quite a few...
http://www.chainreactioncycles.com/au/en/chainrings?f=2258
