Rix said:
160CC of pure addrenalin man, that is awesome! While your add it, port the heads, remove the plug from the exhaust, and she will scream!
Yeah you can get bolt on 4 valve heads for them and big block 185cc kits for only a few hundred bucks. But electric is still the main plan so I won't waste money on any of that. Even the stock 160cc donk puts out 13.5kw which is more than double the original 6kw. It's no sports bike but should be fun.
It kicked to life yesterday, sounded good, then I put the accesssory stuff back on (brakes, drive sprocket etc) and suddenly it stopped working, world no longer run for more than a few seconds and was literally spraying fuel over my leg out the back of the carby. I'll get a new carb for it tomorrow and hopefully that fixes it.
Here's a vid of the test run - she revs pretty quick (I know, I know, this ICE racket is blasphemy
http://www.youtube.com/watch?v=coz01N_ISug
t3sla said:
Conclusive evidence that a 36" unicycle is faster than 36V pedelec
Hah, being faster than a 36v pedalec is like boasting you're more iceberg resistant than the titanic - it pretty much goes without saying
ManoisEscobar said:
Is it possible to just reuse the old spokes and just get a rim off you guys?
Possible ? Yes. Sensible ? No.
If you've bashed around the wheel hard enough to destroy the rim chances are the spokes aren't far off letting go either. Generally reusing spokes isn't a good idea. You'd also need to replace it with a rim of the same ERD or very close to it (same profile so the spokes aren't too long or short) What you could do is get glowworm to cut the spokes to suit one of their rims and have a crack at lacing it yourself for bonus life experience
I've done a few myself and have sat at many a BBQ and family gathering with a motor in my lap roughly lacing up a wheel. If I have the spokes I sometimes do this, get it "near enough" to true then bash it around for a week and then take it to GW for a proper truing. It's fiddley though and certainly much easier with a truing stand, and best outsourced to the experts if you value your time!
Alternatively if you want the cheapest way out uncle Hyena has a used Alex DM24 rim here you can have for free. I might even have a spare set of spokes laying around to suit (you're running a GM direct drive right?) Otherwise $50 odd worth of spokes from gloworm will sort you out and is your cheapest option.
It's going to be more of a 2nd backup bike once I save the dosh for something more ridiculous.
Hyena I have outgrown 48 volts
Awe, they grow up so fast...
Good timing, I'm just about to order a shipment of "something more rediculous"
