Rodney64
I haven't purchased brakes yet either. How are they connected up and I have t used cruise before.
I imagine they're just a simple on off pressure switch (though if the had a linear output that'd be awesome for controllers that support proportional regen) that you connect up to your controllers ebrake line. If you have regen enabled this activates regen braking and automatically cuts the throttle and disables cruise control. If no regen is enabled it just cuts the throttle and disables the cruise. I dont personally see a role for cruise control on a dedicated offroader but it is good on a commuter.Rodney64 said:I haven't purchased brakes yet either. How are they connected up and I have t used cruise before.
I guess I'm subscribing to the 'bigger / more pistons is better' theory
10" floating rotors sounds good to me. I'd buy them now!
What about dual front. One of the cromotor boys had one. Its super rare but surely better and less rare than some custom disc bizoRix said:I guess I'm subscribing to the 'bigger / more pistons is better' theory
I know some will disagree, but as you said, bigger rotors and more pistons are better for stopping. One thing I liked about the gators, they felt like motorcycle brakes. I mean they modulated easy because then needed a little more lever force to lock up. The MT2 by comparison are sensitive as hell. I addapted to only using my pointer finger on the levers because they very sensitive, until they fade. I am really thinking my 9" rotor on the front will solve this problem.
@Morati10" floating rotors sounds good to me. I'd buy them now!
Damn that would be overkill![]()
. There is a company that sells 255mm rotors, I cant remember who, but thats what you would like.
Hyena said:Needs the chain put on and at least 1 brake before I can test ride.
Samd said:Hyena said:Needs the chain put on and at least 1 brake before I can test ride.
You've started pedalling?
I need to go lie down![]()
Die in a fire, I pedal my ring off on my commuter bikeSamd said:You've started pedalling?
Kepler said:Cant complain about my MT2's. Great bang buck. I personally have never had any fade issues with them and the modulation is great. Have found they chew through pads though. Jay, you have ridden MT2's when you rode my Fighter last.
Lately I have been fitting Shimano XT M785 to my builds. Also good value for money with great stopping power and finned brake pads for fade resistance.
I dunno, I reckon it'll be pushing it. We're talking 10+ minutes of continuous flat out acceleration at 5-10kw, heavy regen then back on the juice again. It's almost the perfect way to smoke a motor (at least I'll have continuous airflow though) Either way I'll need to bust out the drill. Ideally I'd give regen the flick to save heating up the motor but in the race situation I'll need to pull up hard at the end of the main straight from ~80km/hr which could be tough on bicycle brakes over and over. I guess it depends on traffic and how much of the track I have to use. I suspect I'll have to sacrifice perfect race lines and possibly run wide or brake too early if I start getting fade.Rix said:The TC 80 on bike rim for road race will be fine
Bitch please :lol:Have your GP rolling when you do.
Hyena said:I dunno, I reckon it'll be pushing it. We're talking 10+ minutes of continuous flat out acceleration at 5-10kw, heavy regen then back on the juice again. It's almost the perfect way to smoke a motor (at least I'll have continuous airflow though) Either way I'll need to bust out the drill. Ideally I'd give regen the flick to save heating up the motor but in the race situation I'll need to pull up hard at the end of the main straight from ~80km/hr which could be tough on bicycle brakes over and over. I guess it depends on traffic and how much of the track I have to use. I suspect I'll have to sacrifice perfect race lines and possibly run wide or brake too early if I start getting fade.Rix said:The TC 80 on bike rim for road race will be fine
I just remembed I also have that crystalyte 5403 laced to a 3" wide cruiser wheel with a nirve fatass tyre. I wonder how that'd hold up leaning it into corners ? The tread seems to run out fairly abruptly so stretching out a hookworm might be a better option for more sidewall tread
I'll actually need to borrow another so I have one forward and rear facing. Or I'll just pinch the dashcam from my car and mount it on the back. It records in astoundingly good 1080p quality for a $50 camera.
