dan974
doesn't it happen when you hit the little gap on the bridge ? doesn't you fork have now a little dead zone about 1cm when going down without any compression ? couldn't be a fork leak ? how far is the last maintenance ?
It's shortly after a gap in the bridge but not immediately. I suspect as Joe said it's bordering on voodoodan974 said:doesn't it happen when you hit the little gap on the bridge ? doesn't you fork have now a little dead zone about 1cm when going down without any compression ? couldn't be a fork leak ? how far is the last maintenance ?
Ultra stealth components from the Hyena Industries R&D departmentRix said:I love your drivetrain. You got the invisible chain and the invisible rear brake. Where can I get some of those![]()
Tell the boys and girls watching at home how many MC rims and tyre sets you have now!going with an 18 MC wheel since I already tried several 19MC and 17MC rim/tire combos
The bike is fine but every time I hit that exact spot it happens. I will shoot a video this afternoon using my patented teethcam(tm) demonstrating the stability of the bike hands free over an assortment of rough and smooth surfaces up until this exact point.pendragon8000 said:did you find the cause of your speed wobbles thing? would be interested to know if you fixed it.
Yeah more watthrs would be nice and it would be certainly nice to just go out for a long ride without having to plan where you're going and distance etc.Rix said:Since it will be an E Moto, might as well go as big as you can. A battery with about 4KW of storage capacity should be enough for about 100Km of range at intermittent speeds.
Sounds like a plan! And out the back we have big custom made tracka - a tight twisty dirt single track with a few jumps and a second second kart style street track for racing 8)Rix said:I am thinking an EBike and Mirco Brewery shop. Get pissed and take piss while your Ebike gets serviced. :lol:
winkinatcha said:Awsome Vid Jay... The no hands stuff looks ace
here's my take...
the bridge is bitumen over planking (guess, I can hear the regular bumping as the bike proceeds along the bridge)
Those bumps, combined with the right speed, are at just the right frequency to kick the front wheel back and forth... you can see the wheel trying to "slap" in synch with the bumpss.... i'm betting if you took the bridge at 50km/h you wouldn't notice a thing. like wise at 15km/h///
But yeah... I would say deffo tank slapper is set up in this case by the constant and regular bumping of the surface which I suspect is planks (wood or concrete) with bitumen laid on top, which will replicate the inevenness/gap between each plank and at the right speed will stuff up your steering...
Joe
Hyena said:With the clutch assembly removed they're only held on by a small circlip. It's actually smaller than the smallest tip I had to my circlip tool so I just distorted them out with a little jewellers screwdriver.
Architectonic said:Hyena said:With the clutch assembly removed they're only held on by a small circlip. It's actually smaller than the smallest tip I had to my circlip tool so I just distorted them out with a little jewellers screwdriver.
Must be the new gear design, because I couldn't force mine off when holding the clutch assembly and pushing hard with the gear on the edge of a table. And yes, I took the circlips off first.
I ended up damaging the gear trying to get mine off (the gear slid against the bearing mechanism). Didn't realise it was a problem until the noise a few rides later.
On a different note, bicycle saddles: I'm guessing you guys have tried a few? The only saddle I have liked was the original Giant branded saddle, which is well and truly worn out now. I'm struggling to find a replacement which is truly comfortable for commuting? I've tried a Clarks 'comfort' saddle and Fizzik mtb saddle and they were both horrible. I'm average when it comes to build, so that helps (5'11", 70-75kg etc).
I'm asking in this thread because all the Aussies regularly read this thread. :wink:
