I cannot acces parameter settings on KT-LCD8S
Kazuno
Denmark
Hello everyone,
I am trying to acces the parameter settings on a KT-LCD8S and does not work, I read almost 10 user manuals and tried every single button combination within the 5 seconds after turned on. Did you had issues with this? Any help will be very appreciated
Is it a kit system (DIY), or one that came preinstalled on a prebuilt brand-name (OEM) ebike?
Some OEM systems are locked so can't be accessed by the end-user.
If it doesn't ask for a password when using the standard setup button combination, it's likely that it's simply locked out from the factory. :(
If you're lucky it might just require a special combination or sequence to get to the password part; the password could be anything but is probably a common number like in this thread:
If it's the display itself that is locked, you could replace it with a standard version, as long as it's firmware/etc is compatible with your controller (you won't really know until you try it).
If it's the controller that is locked, a standard display wont' change the behavior, and a new controller would be needed.
