i have a problem with my powabyke euro
NancyK
hi everyone i have just bought a 2nd hand powabyke euro i has an intermitant power loss when its on the power setting if i turn off the throttle and then power up again it kicks in but then it drops power again can any one suggest what could be causing this,also does anyone know where i can get a manual for it as i dont have one thanks in advance nancy
Often the type of problem you describe is caused by a worn out, damaged, or just undercharged battery. Figuring out if it can be saved starts with getting a voltmeter. Look at plug connections, from battery to controller, and from charger to battery. Sometimes batteries seem charged, but the green light goes on also if the plug is disconnected. So it could be as simple as a bad connection from battery to charger.
Had a similar issue with my euro too,turned out to be the throttle.Not sure where you are but Frank Curran @ http://www.powabyke.com in the UK knows these bikes inside out and they stock most spares for this model.
