it is a control unit and a TF-100 display for an electric scooter. I don't know how to connect it correctly. stage and hall I have 100% correct sensors. the problem is in the gas control.I can only see half of the “thing” on the bottom left. Probably need to see the whole thing to know what the thing is. Looks sort of like a trigger throttle with display of some sort.
That is a TF-100 display. I usually see those with a molded plug. Were these purchased as a kit?
switching speed 1 2 3 in the menu there are 15 different settings... setting volts etc. I don't know much about it. I removed the cover of the unit and connected the cables from the display according to the diagram. error E-006What features does the controller support?
Yes have a multimeter. the wire is 5Your TF100 display has 5 pins like most displays do.
-Red is battery power.
-Brown is ground
-Blue will change from 0V to battery when display turns on
-Green is data
-Yellow is data
The problem is that the controller doesn't have a matching 5 pin plug. I see a six pin plug in the picture. You need a clearer view of that plug. Does it have five wires going to it or six wires? It seems like one of the pins is missing. Are there two grey wires going to one pin?
Answer that question first. Then maybe you can move on. Do you own a multimeter and know how to use it?
Blue display on-54V off-0VYour TF100 display has 5 pins like most displays do.
-Brown is ground
-Green is data
-Yellow is data
