ChaosGT 1600 ehlp on Electric connection
Kikko1979
London
Hi every one could you please help me Can you tell me where I need to to connect this wire As I try to change the bottom start and I forgot how the cable go and I can make the motor go Se picture attached
Please I’m really not good on electrical Staff
There are several wires in your pictures.
Which wire are you talking about?
What were they originally connected to when the system still worked?
What are you trying to connect them to now?
What are you trying to make it do now that it didn't do before?
More detail is better, to help us help you.
Hi mate thanks for the replay The yellow and and red ones The issue is the I can change the speed 1/2/3 But I do no where the go the the red and yellow as the acceleration Is not working and must be one of them the make the motor Go Any Help Mate please
What have you tried so far? I noticed in your second and third pic, you have the yellow connected to the two black wires? Have you been randomly been trying different combinations? If so, and you connected the red conductor to the wrong wire, you could fry the controller’s 5v circuit. You’ll likely need a voltmeter to troubleshoot with, and to check that the controller is still functioning.
Can you confirm what functions the throttle supports? The replacement throttle for that scooter appears to have a 6 conductor connector. Is the pushbutton switch for the horn, and key switch to turn the scooter on and off? Are the other functions besides the throttle working?
