mike662
Hello everyone! Last year I decided to buy a Golden Motor 1000W rear hub motor kit. My goal was to build a bike that was fast and stealthy (not able to tell it's electric). So far the bike has served me well, but my concern is that since the dropouts are aluminum, I won't go past half throttle and even then I'm worried that one day my wheel will suddenly fall off. Now I don't care so much about stealth and I would like to convert to a chain-driven motor, such as the Cyclone. I have browsed around for hours online, trying to find information but I have found little that helped me understand what I need to make this project work. So I was wondering if anyone here could help me out a little to understand what I will need to make this all work. Here are my questions:
1) Will my 48V 12ah lithium battery from Golden Motors work well with the 1200W motor from Cyclone, or will it be under or over powered?
2) What is the difference between the one, two and three chainwheel kits found on cyclone-tw.com?
3) I have attached photos of my bike. Do you see any problems with mounting the motor or anything else?
4) Anything else that I should be aware of in installing the motor and crank and stuff? I see a lot being written about alignment, cadence, etc., but I do not know what this all means. Can anyone explain?
Thanks so much in advance. I know I'm asking a lot but I really don't know that much, even after trying to search through the forums.
Mike
Mike
