hydro-one said:
all you ice bikers out there, tell us your secrets, sheet metal screws, etc etc i know madrhino must have something to say on this
Coincidence, I am just making a set of ice tires right now :wink:
First, all the ready made bicycle ice tires that are available on the market, are way too short on knobs for my off road need. Best tires for winter use are Nokian, and Schwalbe are not bad, both do offer hard gum tires. Chose a hard gum mud tire and stud it yourself, nothing can beat this.
The studs need to be hardened, so if you want to use screws your best bet is to chose self drilling metal screws. Here is what I am using right now:
Cut the head off, and stud your tire so the drilling tip of the screw is out of the knob about an eight of an inch. Start the tread in the knob with a normal screw of the same size, then screw the stud holding it with small Vise-grip long nose pliers. Many patterns can be done, the more studs giving the best ride. You can also use the head side of the screw on part of the knobs if you plan to ride on mixed surface, this will help the studding job to last and work better if you ride on surfaces other than ice. If you want to use the head of the screw, best is to cut a cross in them with a Zip disc after they are set in the tire knobs. The heat produced by the metal cutting on the head will glue them strong in the knob rubber, and this cross cut will make them screw heads more aggressive too, according to how wide and deep you do it. The screws that you want to use the head have to be cut too, according to the height of the knob, you want to leave about a third of the tire thickness intact inside.
Here is one that is not finished. The screws that I use the head are all set and the cross cut done on them. All the remaining knobs of the tire will have a screw tip, like those that you can see on some of them already.
