recumpence
1 GW
I have been thinking about a "Perfect" kill switch. You cannot just kill the center leg of the throttle POT because it is poccile the ESC can go into a fixed throttle mode and take off. It is rare, but I have had it happen to me. So, a positive disconnect is needed. For high power applications, a contactor is really not feaseable and a remote mechanical plug puller is really ghetto. So, annoyed at this delema, I think I have come up with a workable solution.
My idea (and bear with me, I am only slightly electronically inclined
) is to use a few 4110 FETs in parallel as a main power switch. One main power lead would get its power through the FETs. So, a simple switch, even a keyed switch, would send power to the FET gates and turn on the FETs and also turn them off. This would, in effect, act as a main power contactor. It would even be good to eliminate the plug-in spark associated with plugging the pack in. You could either setup a very simple cap charging circuit that would fire the 4110s only after the caps were charged, or you could merely use enough 4110s to handle the innitial cap charge hit.
Anyway, that is my idea. What are your thoughts? Are there any inductance issues or anything else you can think of that would thwart my otherwise awesome plan?
Matt
Matt
