Well I read these BMC's you can go high wattages. I think its rated at 350 or 500W, but I will do 750W and see.
I cam to the conclusion that instead of fabricating a homemade freewheel from a rear wheel hub, I will turn it into a front motor. Now the flats maybe too wide, I havent eye balled it yet, but it will be easy for me to cut the axle to extend the flats inward.
I am getting tired of the drag direct drive motors cause. So I will use DD on a bike where I intend to do little pedaling carrying lots of batteries and just cruising around, and the geared motor on a light setup (A to B setup).
The only other geared motor I tried was a wimpy ass geared BRUSHED motor that came from Canadian Tire, 250W and I burnt the brushes on that in short order.
I like tons of torque but speeds no more then 40kph, cruise at 25-30kph, thats where I want my high efficiency range.
