This rate is a recommendation that aims to enhance cycle life at the cost of your time and convenience. Our tests confirmed its capability to be fast-charged with up to 6A. Utilizing 4A didn't inflict any damage on capacity or discharge rate.@AmericanElectricSolutions Your original post mentions 4A max charge rate, but the battery itself says 2.5A max charging current. Where did the 4A number come from? I tested charging through the smaller charging leads at 4A before I realized the discrepancy, but don't want to cause any unnecessary damage.
If you have time you could charge it at 1.5A even and it will last about 15% longer.
Manufacturer states 60 peak for 5-6 seconds then back to 40how much amps are you able to push from these batteries before BMS trips?
