I have now done some measurements of the maximum voltage and current.
The circuitry is specified for operation up to 80 V and abs max 100 V. The tranzorbs I fitted are 100 V nominal turn on; they are what you would use on 85 V systems. So operation at 72 V is in theory perfectly ok, but we have to allow for the fact that 72 V batteries are sometimes more than 72 V.
I've just run one up to 120 V (with a series resistor). The tranzorbs limited the on board voltage to 98 V and the circuit still works.
On that basis, the occasional excursion to 90 V, which is what freshly charged 24 cell LiFePO4 would be, should be OK. I wouldn't do it in a pacemaker or a satellite, but I would do it on a race vehicle.
Max current is more difficult. It all depends whether you mean peak or continuous. A short peak can be anything you like, up to the package limit of 120 A. But for continuous, you have to be aware of the FET characteristics.
As a FET warms up, the on resistance rises dramatically. You can then get thermal runaway, as the higher resistance leads to more heat dissipation, and thus higher resistance.
For continuous current, the limit for this unit is 20 A. At 10 A it is nice and cool and the dissipation is 0.7 W on the whole PCB. At 20 A the FET alone is dissipating 5 W. (For comparison a Schottky at 20 A would be about 15 W and definitely need a heatsink.)
But at 20 A continuous, the Anderson Powerpoles are also getting hot and so are 14 AWG cables.
Remember this was intended to be something not much bigger than the connectors and for use without a heatsink, for battery combining, etc. 20 A is fine for a lot of purposes. Going higher can be done simply by paralleling up the boards.
To get above 20 A continuous in one unit can be done, but it would require not only heatsinking the FET, but beefier connections to the board, so it would be a very different type of package.
Nick
