Identifying Bafang Hub motor
Dunlop
Hi, I am new to the forum.... I have attached a pic, with the numbers from my Bafang hub motor that comes on a BPM bike. Does anyone no what any of the number mean? I am sure some are date codes or batch numbers, but I can't find any info at all.
Thanks for looking,
Keith
What would you like to know about it?
Thanks for looking,
Keith
This thread may help some:
https://endless-sphere.com/forums/viewtopic.php?f=2&t=109866
Thank you both for responding..... Yes I did seen the other post on the same motor, a while after I had posted this.... So I guess so far I have learned:
1. It is indeed a 1000w
2. The wheel specs say: Wheel Diameter (Inch) 26/700C/28.... Mine is spoked to a 24" wheel. This is going to make it slower??
I am trying to learn all I can here, and I couldn't find much of anything from the Bafang site, other than it appeared to be what they called a "H550" series motor, but wasn't really sure. It appears to be fairly Hi-torque, so maybe it will be able to pull my fat azz up some of the hills here in AZ.
I really posted because I couldn't find any info about the KT controller that it came with it (see my other post), so I decided I could look up the Motor, and find what kind of controller they recommended to go with it..... but that didn't work either.
Keith
slower, but with higher torque, assuming it is the same motor winding as the larger wheel size. (winding the motor differently inside changes the speed too).
Where in AZ? There's not much in the way of hills for most of the Phoenix / valley area. The few there are can be pretty steep, though.
I guess the real question is, what exactly do you need to know, and why?
If you're just trying to find out if the system will do what you want, and you already have it, just try it out. ;)
If you don't have it yet that's a little harder. ;)
I am in Lake Havasu.... The town is built on the side of a large or small mountain! Lots of ups and downs!
Again, because I was having difficulty deciphering the numbers on the KT controller that came with it, I thought that maybe if I was sure of what the motor was, there would be a recommended controller to go with the motor...
[/quote]
I do have it... It has all of 2.8 miles on it, and now the PAS doesn't work :oops:
https://www.endless-sphere.com/forums/viewtopic.php?f=2&t=114461&p=1692626#p1692626
How steep, and how long, are the hills you have to ride up? That will determine how much power you need and for how long. That's important not just for hte motor and controller, but for how big a battery you need (Ah/Wh) and what kind of C-rate (current delivery ability) it will need to have.
(the battery is the heart of the system, since it must supply all the power the system needs, for however long the system needs it; if it can't, or if it stresses the battery to do so, the system wont' do what you want, or at least not very long).
That depends more on your specific needs than which motor it is. You don't want to use a controller that is way more than the motor can handle, if your riding situation is likely to frequently push the motor harder than it is designed to.
So there are a couple things about the controller:
First, do you have any specific needs for how the controller works?
Meaning, for instance, do you need it to operate via throttle only (ever, or always), or via PAS only (ever, or always), or do either depending on your choice at the time? If via PAS do you need it to respond to how hard you pedal, or just that you are pedalling at a certain speed? Or just the basic PAS that gives full power at whatever level of assist you set whenever you are pedalling at all? Do you want it to be user-settable (programmable)? Or do you want it purely plug-and-play with nothing to setup or change (which usually means being *unable* to change anything). There are lots of other possible things a controller might do for you, so if you think about how you ride, and what kinds of things you wish a bike could do, make a list, then we can see about finding a controller that will do that for you (if there is one).
Second, it has to be able to supply enough power to the motor to do the things you need it to. (that's something you will need to define as precisely as possible, overestimating your needs if you have to do any guessing). The motor is "1000w", which means it should be able to sustain 1000w continously; I have never used this one so don't know how true that is for this specific motor. I had a Fusin "1000w" motor but it was really only meant for half that continously, and could handle a few minutes at 1000w as long as it was running at or near full speed (if chugging along at low speed but high load it could overheat really fast).
Ah; somehow I didn't connect the two threads.
It's not uncommon for someone to post two different bikes' problems as separate threads like that.
FWIW, when there is only one single project or problem bike, it's easier to help someone with it if they post everything about that problem in only one single thread, because then all the info is there in one thread, and everyone helping can see all the info without hunting down other threads. ;)
I have been trying to figure how to answer all this, but here goes: The lake is at 450ft (above sea level), My house is at 1300 ft. The straight line distance is about 4 miles. That is average 3.8% grade... Some parts of the hills are steeper than others so the town is made up of ups and downs from 5% to 1%... LOL Ya, there is nothing truly level around here!!
The bike was purchased in July, from BPM Imports... It is a full suspension, 24" fat tire bike: 1000W Bafang Hub motor, 21A-H Battery made with samsung cells, durado type battery. (Seemed pretty bad-azz on paper anyway).
My style of riding: Theoretically, the throttle is just used to get going, or move quickly through intersections, otherwise I need the PAS working all the time!! I rode my wife's bike, and some of the longer up hills found myself using the throttle to keep up the speed, and take some load off! I would think as I get back into riding again, the throttle use should diminish. On the downhills, I am wishing for higher rearing so I can go faster... momentum helps get up the next hill, and a fat tire bike has some serious stability, like a small motorcycle, rather than a bicycle. Her bike is a 750 no-name hub motor, but I get 35mph on a good downhill.
I hope this gives a little bit of a feel for this areas riding.... The town was designed with help from Walt Disney, and looks like someone threw a bowl of spaghetti on the side of a hill!! Many trips take you a crossed the side of the hill, but due design, it means you go up and down. In my truck I am constantly hitting the trailer tow button to keep my speed down on the downhills (and to save brakes), or you have your foot in it, because you are going up!
I hope this answers all the questions from above. I really appreciate the time you have put into your responses.. To be clear, I bought this bike to get some exercise!! in an area where bicycle riding is just not very popular, because of the hills. I am always pedaling (as time goes on hopefully pedaling harder and longer). I do not ride it around like a motorcycle (throttle only)... I have plenty of motorcycles already!!
Thanks,
Keith
that should help; i have to go out and do more yard cleanup while weather is good today and while i have help, but when i'm too wiped out to continue that i'll be back inside and will go thru your info and reply.
Ok. So, with the info provided, and a guess of 120kg (230ish lbs) for bike plus rider weight, then this
https://ebikes.ca/tools/simulator.html?motor=MMAC10T&batt=B4823_AC&cont=C25&wheel=24i&frame=fat&mass=120&grade=5&axis=mph
simulates your bike/situation using a mac 10t motor that may be similar to yours (grin doesn't have your motor in the simulator) and a "custom" 15A controller to approximate yours. The simulation results could be very different from your bike, but you can play with that simulator to see if various simulations match the equivelent actual ride; if they don't, you can change simulator equipment settings until they come close for the same ride parameters.
It says you could ride 17mph at full throttle (or full assist level with PAS) up that 5% grade without overheating, with a 15A controller. (the motor will be over boiling, 110c, for the mac 10t, no idea what temperature your actual motor would be, or if it would overheat). If you don't get that speed on your ride under those conditions, then it doesn't match your system, and we can figure out what might better fit.
The 15A (at 48v) would be only 720w, so if it's a 1000w motor then as long as you're able to maintain near full speed up a hill, the motor should be ablet ot ake it. If it slows way down on the hill it can overheat the motor as it won't be in it's effficient range.
You could use a 20A controller for 1000w if it's really able to handle 1000w, and push harder up the hills to maintain the speed. The simulation gives about 20mph for a 20A controller (with the mac 10t motor).
On the flats, your actual max speed will depend first on the voltage of the battery, for the same wheel size and motor winding, the higher the voltage the faster the speed (above about 20mph the wind resistance also matters so you need more power to compensate, and thus a higher A controller and possilby more capable battery depending on how many A (not Ah) the battery is designed to handle (C-rate)).
That usually means the bike doesn't have a low enough gear, or you didn't shift down enough to keep your pedal cadence fast enough, or the assist level was set too low in the controller/display. Depends on how her controller works.
You can get higher pedal gearing, by changing out either front chainrings (for larger rings) or rear cluster (for smaller sprockets), depending on frame design and what gearing you have now, but this may decrease the ability to ride at slower speeds up hills by pedal power if the motor system has an issue for whatever reason.
If you need faster *motor* speed downhill, you either need a faster wind of motor, or you need a higher voltage battery and controller system, by proportionally however much speed you want vs the speed you get now, by pure motor power on the flats. Meaning, if you get 20mph on the flats under just motor power, and you want 40mph, you would need twice the battery voltage that you have now, and a controller that can also handle that. And a new motor that can handle the power needs of going that fast, whcih will probably be twice as much power as your existing motor is meant for.
The downhill pure motor speed will also be dependent on the same kind of things. If you get 35mph downhill by pedalling hard / full throttle then basically coasting (your motor and pedals probably can't contribute past 20mph or so, based on typical fatbike stuff I've seen for your wheelsize/etc), then to go faster you need to also be able to do that speed on the flats. (wind resistance is a major factor at those speeds.
In that case, you would want to be able to turn down the assist level as time goes on, usually by just changning which level you use on the display. So if you have say, 7 levels on there now, and level 0 is no assist, 1 is min, and 6 is max, with 7 being throttle only, then you'd use level 6 to start with, as long as it lets you put some pedal force in at the gear you shifted to on the bike for that speed and terrain. Later as it is easier to pedal, you use level 5, and so on down until you are at teh balance of pedal vs motor power you really want.
There are also systems that let you use a torque sensor, so that it requires a certain amount of pedal force to even activate the assist, and then the motor provides proportionally only as much assist as you have chosen , for the specific amount of force you put into the pedals.
One of these solutions doesn't require you to replace your controller at all, and uses the Cycle Analyst v3 from Grin Tech, along with a compatible torque sensor (usually these replace the whole bottom bracket unit that the pedals are bolted to, like the Erider, etc, so you have to get one as wide as your current one so your pedals clear your frame).
The CAv3 outputs a plain throttle signal so your PAS on the controller doesn't have to work, and the torque sensor replaces your whole pedal and PAS thing, so taht doesn't ahve to work either.
Even if you just use cadence PAS for it, the CAv3 will still replace the broken PAS function of your controller.
The downside is that it is not plug-and-play, and requires configuration and then tuning for your specific usage scenario, which can take some time to get just right. You can have Grin preconfigure it for you for the basic setup, but you'll still probably need to tune that as you use it to get it "just right" for all the situations you use the bike in.
It can be setup for three presets, and one function (of a few) can be setup to be incremented via buttons (like the assist level on your controller does now). You would turn your bike on, set the exisitng assist level for throttle control to max if needed, then set the CA's buttons to desired level, and ride.
The actual CA doesn't have to be on the handlebars with your exisitng display; you can run it remotely with just buttons on the bars. (you probably do need your existing display to turn the controller on and set it to the right assist level each time it's turned on).
I use just cadence PAS with the CAv3 to run my SB Cruiser trike (eventually I'll use the torque sensor but need to modify things for my specific needs first).
The simulator looks very cool!!! We will have to see how close it is.
So today the tech dept from the importer confirmed they do have a replacement controller in stock (So Cal), so maybe this week we can get one in the mail. I also have a PAS sensor I ordered from ebay last week that should come in later this week.
So where do I find the "C" rating of my battery??? I think I have supplied all the specs I know, but not that one...
I am thinking about using the C10 reset function just for the heck of it... Last night I went through and wrote down all of the current "p" and "c" parameters... Just haven't pulled the trigger yet!
Keith
DOes it have a listing for how many amps (A, not Ah) it can output? This is often but not always stated as Max amps and Continous amps. (I may have missed that in your posts, sorry if so :oops:). They don't always list it as C-rate on whole packs, though individual cells usually do.
(C-rate is just how many times the Ah it can output in A, so if it was a 20Ah pack wiht a C-rate of 2C, it coudl output 40A. (2C x 20Ah = 40A).
Here we go again trying to figure out what these battery numbers mean:
It is a Reention Dorado Max 48v, 21AH Battery.
The 35 in the number refers to the 35e cells from Samsung, and the J4821 is V and AH.
I have found sellers listing max discharge rate of 20A to 30A, and when I put "c Rating" into my google seach I found a site called Heyeienergy stated C=1.... I also found one other site listing short term ratings all the way up to 45A.
Don't know if this answers the question EXACTLY, but it is the best I can do with my mechanical engineering brain. :?
We can guesstimate with that.
Generally the cell ratings are higher than you'd really use in a pack, because they assume specific lab conditions at room temperature, for just a single cell in open air, typically. In a pack they'll heat up and have higher resistance and lower rates, so a safe assumption is half of whatever the lab cell results are for continuous discharge use in a pack. Max ratings are typically a few seconds only, so I would just ignore those for your purposes. I'd also use the lowest rating you find, because many people like to exaggerate the capabilities of whatever they're selling. ;)
This site:
https://lygte-info.dk/review/batteries2012/Samsung%20INR18650-35E%203500mAh%20(Pink)%20UK.html
tends to be reliable for ratings, and it calls that cell an 8A discharge cell (continuous), max of 13A. Since it's 3.5Ah cell, that means it's C-rate is 8A / 3.5Ah = 2.3C. But since it gives us actual Amps per cell, that's even easier. :)
Regarding the C=1, that probably means that specific cell manufacturer's cells can only be used at 1C, which is typical of cheap and/or recycled cells, which is probably what they have or use or make (I've never heard of them; there are hundreds if not thousands of cell "makers", sellers, etc). It likely doesn't apply to your cells, especially if yours are genuine Samsungs (no way to actually know, there are so many re-wrapped recycled garbage cells out there, and other forms of fakes and exaggerations).
AFAICR, Reention Dorado is just a case and mounting style; anything can be put inside them.
To know what the current capability is for the pack as a whole, knowing the Samsung 35e cells' capability, you would need to know how many parallel cells there are (the xP number in 13s4p, or whatever). We can guess that based on the Ah rating, vs that of the cells, which is usually listed as 3.5Ah. Your pack is listed as 21Ah, so 21Ah / 3.5Ah = 6, meaning there should be 6 parallel cells in there (and since your pack is 48v, it's a 13s, 13 parallel sets in series, making your pack a 13s6p pack).
If you want to verify, a good guesstimate can be made: If the pack is at least about 6x 18mm wide for a rectangular cell layout, (minus a bit for overlapping cells if they're in a hexagonal pattern), and at least about 13x 18mm long, and at least about 1x 65 mm tall, then that would match 13s 6p. 13x6 is 78 cells, so 78 x 48g is about 3.8kg, or about 8.4 lbs. Plus or minus however much space and weight cell holders and case itself take up. ;)
So if it is a 6p pack, and each cell can handle 8A continous, then that's 6p * 8A = 48A continuous, at least while the pack is new / healthy (will decrease as it ages, meaning more voltage sag for the same current).
At 48v average, 48v * 48A = 2300w, so your pack should handle at least 2000W easy continuous, and peaks of twice that for a few seconds at a time.
So I think the battery can handle almost anything you throw at it, if it's genuine. :)
This is a pic I found when I was looking for info on the Dorado batteries. I found a chart that makes me think there are 80 of the 35e cells in my Dorado Max. Also, everyone that sells these batteries is claiming 5.5kg for weight. I am glad to know that I wasn't completely wrong when I first saw this bike/package. I stated earlier I thought it looked pretty badazz on paper.
For a 48v 21Ah pack of genuine 35e cells, it should be 78 (13s * 6p), rather than 80 (13s * 6.15p, which isn't possible), since there is no purpose to having two of the 13 groups be 7p, or one of them being 8p, which is what it would take to get 80 cells into a 13s 6p configuration. (They wouldn't waste the money on two extra cells that benefit essentially nothing)
If it is not a 48v (full charge about 54v) pack but actually a 52v pack, then it is 14s (full charge about 58v), and would be 14s x 6p for the 21Ah, which would be 84 cells (and be one group longer physically).
BTW, if that image is actually how your pack is built inside, it is only 10 cells wide x 5 sets long, whcih is only 50 cells max (assuming all positions are full).
For a 13s pack, that would be 50 / 13s = 3.84p groups, which isn't possible, so they would be leaving some of those cell positions empty, to make 3p groups, and thus only half the size of the pack needed to give the capacity yours is specified to be. It would also weigh only half.
To get 21Ah each cell would have to have 7Ah and that's not possible in an 18650 sized cell (and even if it were, they certainly wouldn't be the cells they claim--those would give only 10.5Ah at 3p).
For a 14s pack, that would be 50 / 14s = 3.5p, so same as the above, still only 3p, and still not possible to get 21Ah.
They could use two modules, end to end or side by side, laid out like that image shows, probably neither one full, to get teh 78 cells needed to provide the specs your pack has.
I should have posted this chart when I saw it.... The pic of the cells is just an example of the way they pack a smaller Dorado battery case. My 48v 21AH has the dimensions of the last one on the list... and now that I look at it again it says "80 Max" cells.. So that is the Max number that can be in that size case, not what I really have.
Sorry for the confusion,
Keith
