So, it was recently discussing that at a constant power level as would be true under a fixed power level, that a higher motor voltage would result in higher motor currents and a lower bike speed resulted in this higher motor voltage due to the decreased back EMF. This had the effect that motor current would be greater than battery current. I didn't understand what was so shocking about this relevation (Probably because I made the simulator), but it became more understandable when I considered that the most popular simulator used didn't display motor current so I could understand how it was a bit of a mystery.
So today, I will look at comparing full throttle to a lower throttle and see how that affects the motor currents.
At lower throttle, your motor voltage is decreased due to the magic of PWM, which decreases your motor current just like decreasing the voltage to a resistor lowers your current. The following things are true at 50% throttle and full throttle and no current limiting.
-50% throttle will have HALF the motor current at exactly 0 RPM than full throttle
-50% throttle will have its motor current go to zero at HALF the RPM of the full throttle case.
Another factor to consider is, what does a current limit do? It was recently shown in another thread that the battery current is "multiplied" into a higher motor current during current limiting, and it seems some were mislead into believing that phase currents actually were higher than they would be otherwise at full throttle (i.e., no current limit, full throttle) due to the wording. What actually happens is that the current limit restricts the power (keeps it constant) at lower speeds, whereas at full throttle, the power continually increases until reaching a maximum at 0 RPM, so the current limit "bends down" the motor current and results in a lower motor current. See the picture below.
So taking those things into consideration, it seems almost too agreeable that lower throttle = lower motor current and lower current limits = lower motor currents. When you're limiting or decreasing the power, motor power doesn't increase. From those graphs, it also shows why regular ebike controllers include current limits. So that the motor/phase currents are low enough so that the controller doesn't instantly self-destruct.
There's been some controversy (Actually, the only controversy seems to come from one member... *ahem*), so I'll show more "practical graphs".
Here's the 5302, 100v, 20 inch rim, 50 amp current limit, .01 ohm battery resistance, .01 controller resistance. This isn't actually representative of real life because the battery resistance will typically be more than .01 ohms (That's like 2+ kWH of 30C Lipo with short 4 gauge wires), so they'll be less in real life, but the differences will remain comparable.
And here's the same 5302 with a 100 A battery current limit.
As you'll notice, the 0 RPM current for the 50 Amp one is ~260 amps while the 100 amp one is ~360.
At 50 mph, the 50 amp one has a phase current of around ~90 amps while the ~100 amp one has a phase current of around ~160 amps.
So, an obvious conclusion, a lower battery current limit results in less motor current at any given speed (except the no-load speed where they both go to "zero", or technically the no-load current.), but they'll approach each other as it tends towards the no-load speed (The fastest your motor can spin at a given voltage) and will equal each other once both are outside of current limiting.
I reserve the right to edit this post at any time, without notice, to correct any accidental miswordings
(Caveat: the above assumes an "ideal battery", i.e., no internal resistance. Batteries with larger internal resistances will deviate from the ideal results above and reduce the full throttle phase currents because their output voltage will significantly decrease at higher currents.)
