In praise of hose clamps :)
jonescg
Perth, Western Australia
Hi all,
We have decided to lend the original alloy framed bike of Katherine's to a friend. This meant removing all of the e-bike gear and installing it into my shitty old steel-framed trek I bought in Vancouver for $150 (and proceeded to spend $300 on making it rideable). When I brought this bike home with me to Perth I thought it would be good to have a spare bike for when I have a flat tyre on the Louis Garneau or just feel like a change.
Well now the steely trek is an e-bike.
I couldn't get the captive nuts to work since this frame is a bit smaller than the alloy frame it was originally installed on, so I decided to bite the bullet and add a pair of hose clamps to either support.
Wow. These things are rock solid. Now I don't sound like a freight train rolling through campus :lol: The steel frame has a nice amount of give in it, so even bumps don't jar as bad as they used to. Oh, a shameless plug for our local arts radio station. Big shout out to Joe from Midland!! ;)
The controller had to sit on a make-shift rack until I can find a basket rack to mount on the back. Seems to work, but waterproof she aint :)
The cell_man triangle pack is still going strong. 10 Ah is no drama, but it seems to be doing a lot of balancing nowadays, especially when I leave it in a discharged state for a few days. I think we're on cycle number 250 and have put over 6000 km on it. I would expect nothing less from a quality ES supplier :D
Nice quick solution. I'd add one more on the vertical as high as practical...I don't trust a hose clamp long-term.
That Cellman pack is slick. First time I've seen one. Does he do those customer order, or does he have certain dimension triangles?
John
No, Paul only makes the pack as a bunch of cells in a triangle, and nowadays they come shrink-wrapped. I got the box fabricated out of polycarbonate and dremmelled the Cycle Analyst into the lid (and made a botch job of it :lol:).
But the attachment system using the captive nuts to hold c-channel was OK, and I'm amazed it lasted as long as it did. Now, this thing is so solid I can go jumping gutters and nothing come loose. It pops wicked monos now too :D I just wish it was a bit more waterproof. Even humid air is enough to cause the Cycle Analyst to lost it's display until it dries out again.
Though I tend to not trust hose clamps much either, it looks like the way the load is carried, those should hold fine. A few seconds with a drill would make it possible to add two more though. If they do fail, they'll likely loosen up rather than actually let go, so a rattle would let you know one of the clamps stripped it's notches.
That's a really nice box, well done.
The four I have on should work their magic for the time being. As you say, they will work loose and rattle before failing outright.
The only qualm I have on this bike now is the gears - I am in the second-highest gear possible, and it's still too fast to pedal and help the motor out. The highest gear isn't available as the chain rubs against the frame :x
Still, it might force me to slow down a bit and conserve power. ...nah :lol: I'm going to be popping wheelies on this thing like no-one's business :twisted:
Looks like you have the clearance for a monster front gear. Bend out the frame, and put another spacer washer to get clearance for your 14t rear cog.
I wouldn't worry about the controller getting wet. I put all of mine in direct exposure to the elements. Just as long as you have a drip loop. The controller themselves are relatively well sealed. Nice poly battery box. Looks like a setup you can move from bike to bike with relative ease.
Continuing the hose clamp praise, here's a battery box held together with 6 hose clamps:
And a couple of dodgy switch installations using hose clamps (I have a definitive version now, but no photos):
So far the hose clamps I have broken all snapped across one of the slots, except for one that pulled the whole worm-bolt out of the housing while splitting the housing apart at it's folded-over "seam".
Many of the clamps I've used over the years have failed, mostly to hold various accessories to various bikes. I don't think I could even name all of the ways I have misused hose clamps, much less list their failure modes. ;)
Since adding motors to bikes, I have had a few: One was on a cargo pod design on DayGlo Avenger, intended to help clamp it's bottom edge to the chainstay--the rest of it was U-bolted to the frame, and those held fine. Another on a trailer hitch clamp on teh same bike, essentially doing the same thing. One more on CrazyBike2's front forks, holding torque arm in place--failed after months of hard startups and hard braking with regen, slowly rocking it back and forth just a teensy weensy bit till it snapped. The scariest was on the front of CrazyBike2's seat though--it held the front bottom rail of the seat down to the "toptube" of the frame, so when it let go the seat just leaned way back.... :/
However, most of the many many clamps I have used never failed at all, even when I didn't have long enough ones and had to join 2 or 3 of them in series, and sometiems they were not all the same width! :lol:
Amberwolf - The U-bolt idea is essentially what I will resort to once these fail. But hopefully that will be some time away.
