Kurt
Buy your self a 10,000 mile extension cord?
Its 240v all day every day in Au
Kurt said:Buy your self a 10,000 mile extension cord?
Don't you guys have 13A fuses? Everyone knows its the current that counts, not the voltage
ZOMGVTEK said:Don't you guys have 13A fuses? Everyone knows its the current that counts, not the voltage.
Sure there would--it'd have 110 on each phase, so you only use one phase to the GDO and other 110 stuff. Bit of rewiring, but no new runs needed, as long as you're wlling to live without the earth ground.ZOMGVTEK said:The only problem would be there would no longer be 110 in the garage.
There are several plugs that are used for 220V, including a circular locking style with three prongs I've seen on at least one UPS system, and a Y-blade style in at least two formats (30A, 50A) like what's on my dryer and my stove.And yes, I believe the 220V plug in the US is simply a normal one with both prongs rotated.
Doctorbass said:I am tired of waiting the charger to end the charge process at 1700W max power.. I WANT MORE !!!
I have a good idea on "how to... and how it work" but my only experience is that i installed switch and outlets and few breakers.. but never a second electrical box..
Should i go with what it's called a sub panel ?
Any recommandations , or expertise from electrician ?
Thanks in advance
Doc
Hillhater said:In Australia, we are not even allowed to change out a leaking tap washer without a plumbers licence !
god forbid we should consider even thinking about fitting a plug onto an appliance lead , never mind opening the main fuse panel :wink:
dnmun said:i find that a 20A breaker will handle 20 amps continuously. if you push it to 24A they will usually start buzzing and then blow after an hour or so. you can still get 120V at each box in the circuit, that was the point of doing it that way. it just allows you to use the wire you already have in place to carry 240V out to that location. you may decide you need the 240V for an A/C in the bedroom also. a 12G wire will carry more than 20A without problem too. look at how much current people put through their motors with just little 14G wires for conductors and 50A of phase wire current. why is the wiring in the house less capable? seems like it would be more capable of handling the current because it is not wrapped up with all the other wires overheating so it can handle a lot more current. the trick is having solid connections, i also solder each joint. 12G can handle 40A without getting hot imo. so now lets hear some more whining/inspector please help me!!!??
Whilst i am no supporter of a "nanny" state, or regulations generally,...dnmun said:you can buy a gun without any of that hassle. i bot a 9mm semiautomatic pistol for $150 on CL. no questions asked. private parties are not covered by the law...
Doctorbass said:UPDATE 27 sept 2011
I have examined wich option i have on my actual main panel and concluded that i only have two left location for adding breaker. and.. they are on the same pole
so i have two options: i can offset all offsetable single pole breaker above these two free locations to get two poles and get the 240V... in this case the max amp per pole for a single location is 40A so i could install a double pole 40A breaker in the main panel.
OR
The other option is to modify our actual 60A double pole breaker that is for the hot tub.
Teh best i would like to have is 60A dual pole.. but they need 4 locations on the main panel and i only have 2.
Our hot tub already have a sub panel installed left to it 1 feet away that is connected to the 60A breaker of the main panel.. In that sub panel, there is a 40A double pole breaker that feed the hot tub.
so.. our hot tub is connected thru a sub panel that limit it already to 40A.. so my question is
can i install a double pole 40A on the two left location in the main panel that will feed the hot tub sub panel that have 40A double pole inside?.. resulting in a serie dual pole 40A breaker to feed the hot tub?.. and than use the empty 60A for the garage sub panel?
ex:
actual connections
Main panel that have a double pole 60A using 4 locations that is feeding the hot tub sub panel that have a double pole 40A that end to the hot tub
2 free location on the main panel ( allowing max double pole 40A)
New connections
The actual double pole 60A of the main panel will feed the garage sub panel
The hot tub subpanel will be feeded by the new installed double pole 40A in the main panel
( in the hot tub subpanel, there is only a double pole 40A that is connected directly to the hot tub.)
now i wonder if having two breaker in serie ( one is the main panel and one in the sub panel fo the hot tub) that have the same 40A rating is ok ?
Doc
When used as a service, the white neutral and the bare or green equipment grounds MUST be bonded together AND to the enclosure. This connection is essential to the safe operation of the grounding system
In a downstream subpanel board, the white neutral and the equipment grounds must not be bonded together. The neutral MUST "float " on insulators that prevent contact with the metal enclosure and any equipment grounds. Bonding these conductors is hazardous.
marty said:Drawing of panel on the left is not correct if it is the main panel. I copy:
What is the Amps of the main service? You might want to think about a whole new bigger panel with lots of empty spaces for things that have not been invented yet.
