spdas
Aloha, I have the Leaf 14" rim with 48v 1000w low torque/hi speed motor running at 16s 5000mah 66v to 60v.
I noticed when running WOT for a few minutes the phase wires understandably get a bit warm. WOT is 38mph and I use it on a couple of scary car sections of the road, but use mostly 25mph on the flat --------SO-------
1) is there any point trying to fit larger phase wires or are the current size wires "a reflection" of the size of wires on the winding? ie larger phase wires will allow more amperage, but the winding wires will be the first to "let go" rather than the phase wires.
2) Phase wires are SS....any point to going to copper?
3) Any real world advantage to using larger wires from controller down to the hub and going with standard phase wires to inside the hub? (normally there would be an advantage)
4) Is there one phase wire that carries more current than the other two?
I don't think there is an actual overheating problem, but I like to tinker and improve things!
francis
francis
