Ok.... Ok....
Lets roll it back.
He is talking about a bunch of shorted fets so Programming should not even be on the table right now
I SAID DON'T POWER THE CONTROLLER UP AGAIN
Attempting to program applies +5V to the buss and powers everything up.
You dont want that right now.
re- those measurements you took:
Any fet to heat sink must be true isolation "OL" on the meter
Nothing else really matters if you are shorting to case on more than one fet.
Did you use the insulating pad and fastener insulators?
Did you use any sort of thermal epoxy?
Did you use some sort of "silver" heat compound?
first off - you need to touch the top of each fet and measure resistance to the main heatsink.
focus on the isolation issues.
What are the 18 isolation resistances?
Actually, take 36 measurements - switch the leads on each one.
Fet 1:
red on the fet
black on the heatsink
Fet 1:
Black on the fet
Red on the heatsink
What kind of numbers are you seeing?
Take a picture of the bottom of your board.
-methods
