safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
This is an interesting problem...
Starting with my previous ride and getting worse today I've noticed that my electric bikes power is starting to become irregular. Sometimes when I roll on the power it goes through the powerband normally. Other times it will start to "power up" and then just flatten out and remain low. It seems that when I shift and try to rapidly crack open the throttle that it's more likely to occur than if I very slowly and gradually roll on the throttle from down low, but so far that's just my guess, it's hard to figure exactly at this point.
The batteries are fine, I've made certain of that by completely recharging them and testing the voltage and everything and they are fine.
So it has to be one of these three:
1. Motor (it only has 350 miles on it, so that's unlikely)
2. Controller (a very good possibility, it's an unmodified controller)
3. Throttle (I've already broken two of these, but they tend to get stuck in full throttle when they short out, so this is a new symptom)
Given the symptoms already described, what experiences have people had before? Give me a probability factor for each option or give me another idea if you have one...
