I've got two recumbent trikes with Cyclones that have double-freewheel adapter of my own design (to use White Industries ENO freewheel & Surly sprocket).
I also use a pair of 6000RS bearings to support the outer end of the drive shaft.
But I'm currently using a sleeved M8 bolt screwed into the end of the drive shaft for the bearings to mate to.
This is imperfect as threads are never perfect and there is slight runout between bolt and output shaft.
To make better, I'd have to remove the output shaft and get another one machined up with the bearing support extension part of same piece.
Has anyone ever removed their Cyclone's shaft from the gearbox housing (out of it's bearing)?
I see there's a circlip, but my shaft seems quite a tight fit in its bearing.
I don't want to press too hard, unless I crack the alloy gearbox housing.
Any advice would be appreciated.
