Is electric traction control available on modern controllers
aurum
I was wondering if any new controllers have an electric traction control that is capable of limiting throttle inputs using a wheel speed sensor on the back wheel? I live in Seattle and it could come in handy in the rain.
I havent' seen one yet, but if you're handy enough with electronics, you could do it with a couple of reed switches (or other passive or active wheel speed sensors) a quad op-amp chip, integrating the pulses from the two wheels' speed sensors separately, then comparing the voltages, then using the difference to add or subtract from the throttle's actual voltage.
Might not want to ever actually add to it, since going faster might cause slip on the one wheel that still has traction, but slowing down the faster wheel (presumably the motorized one) ought to be ok.
Might take five opamps rather than four, depending on how you mix the signals to get the final throttle input to the controller, but four ought to do it. Sorry I don't have an actual circuit, but using basic op-amp circuits available at a few of the "learning electronics" websites would probably work, once you work out the passive component values needed for whatever voltages you want to run this all at.
This is a great idea, but it's kind of a corner case and thats why we haven't really seen it implemented. I was considering building a 2WD controller with traction control for use in snowy or other low traction environments.
i would love a mtb front disk brake ABS system instead. Surely hould save a big dentist bill ... lol
abs system will do nothing if your rear wheel start spinning with the trottle open :lol: :lol:
yea but will do if u make a emergency braking with front and rear brakes at full power
i was riding at 30kph with the cruise control and forget to release the resume buton so i have to brake but because the bike was pushing all the force on the front i fall and i have hydraulic disque brake ,
if you run only a 36 volt battery pack set up the brake will stop the bike but not a 100 volt lipo set up at 80 amp like I have,
More you try to stop the wheel more the motor will try to draw current from the battery and controller
el_walto said:
ebrake leavers actually are a good added safety device in my mind. Someone should design some with analog regen.
Very simple to do to the levers themselves, but the controllers don't usually support it that way. I've got a thread (or replies in a thread) about this somewhere, and some ideas on how this might be worked around, for controllers that don't do much or any noise filtering on the brake line (RC filtering, basically).
